ECM Trouble
Old Mar 30, 2013 | 11:12 PM
Cars'n'Guitars's Avatar
Car: 1985 Camaro Iroc-Z
Engine: Currently Deciding
Transmission: TH350 Built
Axle/Gears: 3.73 POSI
ECM Trouble
How can I tell if I need a new ECM?
Old Mar 30, 2013 | 11:19 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: ECM Trouble
No communication with the ecm, a running issues when you hit bumps and low serial data voltage.
Old Mar 30, 2013 | 11:24 PM
Engine: Lb9
Transmission: M20
Re: ECM Trouble
If your car is tpi do a search on the 870 to 165 swap your engine response is greatly improved the 165 is alot easier to find as a replacement as well.
Old Mar 31, 2013 | 08:36 AM
Re: ECM Trouble
My car is carbed, will a bad ECM cause no spark if there is power everywhere else?
Old Mar 31, 2013 | 09:14 AM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Re: ECM Trouble
What test was performed to verify the "no spark" condition?
Old Mar 31, 2013 | 09:25 AM
Re: ECM Trouble
We removed a spark plug and attached it to bare metal and there was no spark. We tested the coil and the module and both tested fine, we checked the plugin for the distributor and it off and on shows power to it.
Old Mar 31, 2013 | 09:43 AM
Engine: Lb9
Transmission: M20
Re: ECM Trouble
http://www.autozone.com/autozone/rep...00c1528005c6a8
Tps tart with verifying power to the hei koeo and crank, then check the primary and secondary coil resistance. Verify the engine ground has good contacts and is secure. Don't trust the parts store testing your icm, if the coil and pickup coil and wires test out good that this is a electrical connection in the dizzy or bad icm. Spend the egtra $ and go delphi or acdelco on the icm even a junk hoard you a
Can usually get a few for real cheap.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
mrbird
Oct 20, 2015 03:43 AM
Jlanz55
Sep 29, 2015 08:55 AM
Lmancha96
Sep 25, 2015 08:11 PM
