can anybody look at my datamaster file
Re: can anybody look at my datamaster file
If mechanical you can fix the devise that is the trigger or remove the SA retard setting in .bin. If it is detonation then you will need to add octane. Most likely it is mechanical. Power steering pump, ext pipe rapping on frame, etc could be causing.
