VSS question
Old Jun 26, 2013 | 08:24 PM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
VSS question
I replaced the trans mounted sensor and data logged the ecm. For ome reason the ecm think the car is moving at about 135 miles an hour at a stand still. I thought the pulse from the sensor is what changed the speed. My question is with the ecm reading it at a constant unchanging speed does that mean the wiring is bad ,speedo or cruise control????
Old Jun 26, 2013 | 10:37 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: VSS question
A '91 f-body VSS is a 4K PPM magnetic sensor (sine wave). Sounds like something is not correct...
RBob.
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
GTAman
Aug 27, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
fonzie85
Aug 13, 2015 11:50 AM
mizz0313
Aug 12, 2015 06:45 AM
