Could anyone tell me what these wires do?
Old Jul 5, 2013 | 10:26 PM
WFCaves's Avatar
Car: 92 Camaro
Engine: 3.1
Recently bought a 92 3.1 RS. Getting rough and fast idle (1000-1300).I look at the ECM and find these wires. I do not know where to look to determine what they are responsible for. Any help would be appreciated
Old Jul 5, 2013 | 10:30 PM
Ransford2987's Avatar
Car: 1990 IROC-Z/1980 Firebird
Engine: 5.7 TPI
Re: Could anyone tell me what these wires do?
what wires?
Old Jul 5, 2013 | 10:32 PM
WFCaves's Avatar
Car: 92 Camaro
Engine: 3.1
I suppose actually attaching the photo would help
Old Jul 6, 2013 | 02:05 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Not sure about anybody else but it would help me if you took a picture showing where in the engine bay (Or under the dash?) those were and what it is around. Are you unable to trace the wires? Are there any other cut wires you have found?
Old Jul 6, 2013 | 04:29 PM
WFCaves's Avatar
Car: 92 Camaro
Engine: 3.1
Picture was taken from under dash, where the ECM is. Cut wires appear to go into the door panel. Guessing power locks? Car has the ability for power locks, but they do not work. I Cannot trace the wires of the connector with blue, red, gray, gray/black wires from the bottom half of the picture I attached. It heads towards the front of the dash, but then I quickly lose it
Old Jul 7, 2013 | 06:39 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Ok, all of the wires (nearly all) that go to the ecm will come in from a panel that is just in front of the drivers side door. So just if you are assuming it goes to the door because it goes through that panel you are wrong. Go ahead and drop the ecm down and find out if the wires might go to that. I f it doesn't go to the ecm and your speedometer is working fine I would say it isn't the ecm. Then just check to make sure all of the power locks and windows and heater, and speakers all work. Go from there.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
