Fixed my Speedo/Odometer/Trip after FAST XFI install finally!
Car: 1991 Z28
Engine: 383 Stroker/TPiS MiniRam/D1SC
Transmission: Probuilt-700R4
I have a 91 Z28 with a 383 and Procharged D1SC. I have know clue or time on how to wire the FAST XFI
so I had Jannetty Racing do it for me. They removed the old ECM and installed my FAST XFI to power the car but found out I lost my speedo/trip/odometer.
After 2 years of using my GPS for a speedometer I had enough. After a bunch of searching for clues and help from this site and chevythunder.com I finally decided to dive in and see if I could fix this.
I have a VSS buffer unit out of an 88 GTA but I read somewhere that it was suppose to wire it into my ECM so I figured that was out since I didnt have one powering the car anyhow. So I decided to use the original ECM and go that route first.
This was the mess I had to start with
After some serious wire checking and clean up
The XFI is now up in the dash and zip tied securely. I removed the dash pad to get at everything and secured everything down. I removed the original ECM bracket since it is going to be relocated in the rear of the car.
Items in the rear for mockup
Wires ready for plug in:
Bracket secured with screws ECM installed and zip tied to make sure no movement:
Got in the car fired it up, started rolling down the driveway and had movement. Got out on the road and everything is working perfectly. Checked speed against GPS and it was spot on, trip and odometer are rolling too
Here is how I wired it up:
Many thanks to this site and I hope this helps someone out with the same issue.
so I had Jannetty Racing do it for me. They removed the old ECM and installed my FAST XFI to power the car but found out I lost my speedo/trip/odometer. After 2 years of using my GPS for a speedometer I had enough. After a bunch of searching for clues and help from this site and chevythunder.com I finally decided to dive in and see if I could fix this.
Car: check
Engine: check
Transmission: check
Re: Fixed my Speedo/Odometer/Trip after FAST XFI install finally!
Lol,
Should have come to us first...
Maybe go back to Jannetty Racing to square it away...
Yes, I have no sympathy. You paid them, get them to make it right. After all , they are the ones that got the money.
Car: 1991 Z28
Not looking for sympathy, just sharing how I fixed my issue. I think I did message you and was referred to Bob in Long Island to help me out but I didn't have the time to make the trip out there, deployments tend to hamper that. Either way its done.
How's it run with the XFI? Any issues at all? How much time into the tune so far?
Oh I see it's a fairly mild build so it should run ok.
Car: 1991 Z28
Yeah nothing huge, Golen 383 engine and installation and tuning by jannetty racing. No issues except for the above.
Car: check
Engine: check
Transmission: check
RBob.
Car: 1991 Z28
Where would that Brown wire coming out of the Buffer Box (F-post) gone to if not the ECM A10 pin location?
Seems like over kill wiring up both units to each other when ECM can do it by itself without buffer box which is what I did. I think it is a clean install but to each his own I guess. No issues with cooling so i dont see the problem there. Wish I had all this great advice prior to fixing this instead of just a referral.
Jeff
Jeff
Car: check
Engine: check
Transmission: check
https://www.thirdgen.org/forums/dfi-...echnician.html
You were the one looking for someone to do the work.
RBob.
Car: 1992 RS 25th ANNIVERSARY EDITION
Engine: 5.0L
Transmission: 4 SPEED AUTO
Axle/Gears: ALL OF THEM
That is where it goes for the '7165 ECM. Since that ECM can't buffer the magnetic VSS, the 4-out buffer box is used. I guess the XFI box doesn't have a VSS input? May be able to send it to it.
With the 4-out buffer there is no need to wire in the original ECM.
Need to check your thread:
RBob.
RBob.
Has anyone got a photo of the buffer box, as my speedo doesnt work and i dont know what im looking for. Is this the simplist wiring diagram to work to, photos would be great. Thanks
Car: check
Engine: check
Transmission: check
The above shown wiring is partly correct. The A - H terminals are in the opposite order. You will see that in the picture in the thread.
RBob.
Car: 1991 Z28
So why is there a port coming out of the buffer box to goto an ECM? Why did they waste the time to add that port if its going no where and does nothing.
Huh, funny when you look for post and show how I asked for someone to do the work and then you know how to do it but couldnt be bothered with it until I fixed it then all of a sudden there's input lol. Seems like if you know how it's wired you could have made a sticky post diagram and just directed me to it and we would have never had this conversation. Either way people with my type of issue now know they dont have to get a buffer box and they can just use their original ECM. Personally I like the way it came out and I have no worries either way. Cheers!
Car: check
Engine: check
Transmission: check
The only 3rd gen f-body's with an ECM capable of buffering a magnetic VSS are the '90 - '92 TPI and MPFI equipped vehicles. Even the '90 - '92 TBI f-body's had the 4 out buffer as the ECM used was not capable of buffering the VSS (among other 3rd gen f-body cars).
In your thread you asked for information regarding whom could wire it in for you. Read your thread, I posted the link.
You received several replies of offers to wire it in.
If you asked how to wire it, the responses would have been different. Not only that, there are other threads that show the wiring for it.
RBob.
Car: 1991 Z28
Great, I glad we got that cleared up. Yeah I did say I was looking for someone to do the work as I was in the weeds looking at all those wires. It would have been nice to see....."just do this, this, and this and you'll be good to go." Guess I gotta be more specific next time.
Since my ECM can take care of what I need, then I'm good. Some may not like it because its not easier, cooler, cheaper, etc., etc. to each his own. Like I said, I'm a novice but I think I did good for what I needed to be done and I learned a lot from my Chiltons book and chevythunder.com
It may be a good idea to post how to specifically wire up your buffer box version with a diagram since there are numerous questions dealing with this topic. This way you can just say see......< >post and be done it.
Jeff
Jeff
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Wow I could see why you were asking for help that's quite the rat nest lol! Looks like you got it working either way, good job.
Car: 1991 Z28
I appreciate it. Learned a lot.
Fast355
Dec 2, 2016 06:33 PM
Polo Z03
Sep 10, 2015 06:43 PM
