Gm knock sensor with DFI gen 7
Old Jul 14, 2013 | 07:28 AM
Recaro trans am's Avatar
Car: 1985 pontiac trans am
Engine: Procharged 5.7l
Transmission: t-56
Axle/Gears: stock 9 bolt 3.71
I was able to get my car started thats to the help of Mark here on the forums. After that ordeal I decided to finish adding all my add on sensor I have. So now my wideband is installed, and my knock sensor. The wide band is working great, but my knock sensor is setting a code, I believe 39? I can see the knock reading bounce back and forth from 0 to 6 and some times higher. This is at idle. if I rev it up its fine. I do have a procharger and it is a bit noise so is there a way to adjust the sensitivity, and or shut it off at idle? Thanks in advance.
Will
Old Jul 15, 2013 | 11:49 AM
Ronny's Avatar
Re: Gm knock sensor with DFI gen 7
Only experience I had with a overly sensitive KS was on my snowmobile. Fix was to add a hard plastic(nylon?) washed under it between my head and the sensor. Mine was threaded. Now some sensors are less sensitive than others or read diff frequency. I head once the V6 KS from a full size platform car was less sensitive. Not sure on that..
Or fix the issue with what is causing the noise.
Old Jul 15, 2013 | 12:01 PM
Transmission: t-56
Well since my knock sensor threads into the lower water jacket there is no way to isolate it with a nylon washer. The fix for this has to be within the DFI tuning software. Cause the issue causing the noise is the supercharger, and there is no way to make it less noisy. aside from removing it.
Old Jul 16, 2013 | 10:54 AM
Ronny's Avatar
On older cars(mine) mechanical noise sets off the KS. I ended up reducing the spark retard in .bin but did not disable. It appears in logs but with minimal retard shown. Lately it shows no retard yet I am more aggressive on SA.
Is adding a remote blower(I forget the terminology aka Procharger/Vortec) a given to produce knock retard? I would think the mgf would say it will not cause that issue.
Old Jul 16, 2013 | 12:20 PM
Transmission: t-56
Im not sure if they factor in knock from the ( centrifugal ) blower. But the sensor is mounted on the d/s and so is the supercharger. The Procharger is a gear driven unit and just like they say timing gear sets cause issues with knock sensors it seams as if the Procharger is as well
Old Jul 16, 2013 | 12:51 PM
Ronny's Avatar
If you remove the drive belt from blower will K cease? I would give that a test unless K occurred day one of blower install and car did not show KC's in logs before.
Old Jul 16, 2013 | 01:00 PM
Transmission: t-56
Well I just installed the knock sensor and module for my DFI gen7 only just this past weekend. So any prior log I have no clue, besides that its not a knock. Its only at idle and like I said I can hear the blower whine change pitch at the same rate as the sensor detects a "knock". So its really just picking up the harmonics that the blower is generating, not an ignition detonation.
Stand alone systems like holley have the capability to take the factory one wire GM knock sensor system and adjust the sensitivity as well as how much timing is removed with RPM vs Manifold abs psr %. If I can just figure out how to adjust it in the Accel DFI system I have I think it will be fine and the blower can scream as loud as it wants. lol
Old Jul 16, 2013 | 01:10 PM
project89's Avatar
u can get a brass 45, or 90 degree fitting and screw it into the block then screw the knock sensor into that , which will desensitize the sensor a good bit at low rpms
Old Jul 16, 2013 | 01:19 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
it is 1/4 npt to 1/4 npt, or a Ron Francis knock sensor adapter to go on the oil pan rail.
http://www.summitracing.com/parts/rf...FY87Mgod6xMALw
Old Jul 16, 2013 | 01:23 PM
Transmission: t-56
And that will not change the other characteristics of the sensor? I still want it to be effective.
Here is the link to the site I found that talks about these is great detail.
http://forums.holley.com/showthread....ors-Holley-EFI
Old Jul 16, 2013 | 01:26 PM
Transmission: t-56
Thats wild, lol Never saw these before. I might try machining one of those. I have a few spare knock sensors laying around. Ill try them before dumping coolant all over myself.
Old Jul 16, 2013 | 01:46 PM
Engine: Lb9
Transmission: M20
Modifying a fuel pump block off plate bye drilling a hole and tapping it works as well. you can install multiple gaskets or make gaskets in multiple thicknesses until the knock sensor becomes less sensitive. just a thought.
Old Jul 18, 2013 | 09:53 AM
efiguy's Avatar
Go to "Ignition", then "Knock". You will see an 8x8 table referenced by load and rpm.
At whatever KPA you're getting the idle noise at just 0 that area. If the value is not set to 0 and it detects a "knock" for more than 15 seconds it will default. Therefore the fault code.
And if you have a Pro key you can adjust how quickly it retards the spark as well as how quickly it restores it.
This system has had this programming since '04. Funny how people say the Gen VII is old technology. Simply not so, others are still catching up in a lot of ways.
Hope this helps.
Old Jul 18, 2013 | 11:18 AM
Transmission: t-56
Hope this helps.
Great, the answer I have been looking for all along! lol Im leaning more and more into getting the Pro Key. From looking at the F1 help menu I see all the hidden features that could be very helpful. Thanks again, and I will keep you posted of my progress.
Will
Old Jul 18, 2013 | 11:50 AM
project89's Avatar
Hope this helps.
this is why i dislike so many of the aftermarket standalones or ecm systems , the features are there but u have to pay more to unlock or use them, make the dam system a single price with everything unlocked
Old Jul 18, 2013 | 02:54 PM
efiguy's Avatar
I completely disagree!
I can't tell you how many times I get someone who fooled with stuff that they had no idea what they were fooling with. It happens all too often.
I applaud Accel for doing what others should do.
That's why the Thruster is perfect. Has just as many features as most but is basically a Gen VII with different software.
FYI BS3, Motec and a few others have different levels as well. It's only the FAST's, Holley and a few others that don't limit the accessibility based on the programmer skills. And trust me, there are a lot of "tuners" out there that have no business doing what they're doing.
If you've done as many as I have I'm very sure you'd agree.
Old Jul 18, 2013 | 03:39 PM
project89's Avatar
i can see ur side of it , but its the persons fault for not reading the manual and not understanding what everything does
my very first standalone i did years ago i read that manual front to back atleast 5 times iirc the manual is well over 200 pages
Old Jul 18, 2013 | 05:32 PM
efiguy's Avatar
Exactly!! Guys change stuff just because it's so easy to do. I get cals emailed to me and sometimes I wonder how it even ran, they're that bad.
Old Jul 19, 2013 | 07:25 AM
Transmission: t-56
It seams I may not be able to run a knock sensor with the Procharger. No matter where I am im seeing a trigger from the knock sensor, small about 2 deg but enough to remain constant that the light comes on.
On a side note, what table do I need adjust the IAC so that when I snap off the throttle ( like when coming to a traffic light) the idle will come down slower and not drop down to 300RPM and want to stall before it recovers back at my set idle of 750RPM? Thanks again.
Old Jul 19, 2013 | 08:32 AM
efiguy's Avatar
Throttle follower. Plus make sure you have the throttle plates set correctly. You should see IAC counts around 8-12 when hot and in neutral.
Knock - Zero all the higher vacuum areas and see what happens.
Old Jul 19, 2013 | 01:05 PM
Transmission: t-56
For the Knock sensor 8x8 my car is boosted but the Map axes goes from 0.00 to 87.50. Why? Should it not go from -(neg) numbers (vac) to positive being Boost?
The throttle plates are set to factor spec, what that was I don't remember but I remember having to set them, and then the distance for the IAC. The throttle follower table, What exactly am I looking to move to get the car to idle smooth? IAC position is on the Y axis and TPS position on the X. Mine right now starts at 18% and tracks up to 30.0 around TPS % of 30%.
Old Jul 19, 2013 | 05:56 PM
efiguy's Avatar
For the Knock sensor 8x8 my car is boosted but the Map axes goes from 0.00 to 87.50. Why? Should it not go from -(neg) numbers (vac) to positive being Boost? I'll check, they've changed the software and have now gone back to the 6.1.5.
The throttle plates are set to factor spec, what that was I don't remember but I remember having to set them, increase their opening, reset low TPS setpoint and see what your IAC counts are. then the distance for the IAC.
The throttle follower table, What exactly am I looking to move to get the car to idle smooth? That has nothing to do with the throttle follower. The throttle follower is strictly for the return of the throttle to idle. IAC position is on the Y axis and TPS position on the X. Mine right now starts at 18% and tracks up to 30.0 around TPS % of 30%.
Smooth idle will be obtained by having the correct air/fuel and timing then setting your "Idle spark compensation" table correctly. The IAC is only for A/C activation, into drive etc. It actually does very little for idle quality.
Based on your info, once you properly set the TPS low setpoint and throttle blades your throttle follower at a base of 18 will probably be pretty close to optimum when hot and in neutral.
Old Jul 19, 2013 | 06:45 PM
Transmission: t-56
Right, Perhaps that was a poor choice of words. What I ment by "smooth idle" is when it returns to idle from a quick release of the throttle, usually when coming to a traffic light. When I release the accelerator the RPM's dip down to about 200 and then slowly recover. If I dont heal toe, or down shift it will almost stall. The car itself idles beautiful, if the damn super charger was not so loud you would never know what lurks under the hood. The throttle follower table is a bit confusing to me. Should I increase the IAC % or should I shorten the TPS % slope? If you still have my Cal file it may make more sense what i'm saying.
Also, I zeroed out all the vac region of the table (if they are indeed vac) and now the light wont trigger at idle and light cruise. I am still getting a knock signal on light load highway driven and enough to set code 36. I'm starting to wonder if it would help to move the knock sensor to the Passenger side away from the procharger. Any other suggestions?
Old Jul 19, 2013 | 06:55 PM
efiguy's Avatar
With the engine idling, go to "Target Idle speed", look in the lower right. What is the IAC count? Hot, in neutral it should be roughly 8-12. If it is your current setting of the throttle follower should be decent.
But it may not be obviously. So make sure you have the counts down around 8-12. If they aren't then you need to open the throttle blades slightly, then reset low speed TPS until you have the counts mentioned.
If it still stalls then just go to the "page up" key on your keypad. It'll raise the whole graph.
0 the next line. You'll probably just have to 0 everything except the bottom 2 rows.
Old Jul 20, 2013 | 10:30 PM
Transmission: t-56
So you were 100% right. My throttle blades needed to be opened up quite a bit. I was able to see my IAC counts were up around 40. No wonder the car wanted to stall after a quick throttle release. I opened the blades from the stop screw and watched the counts drop to about 9. Now the throttle table actually makes noticeable changes and does not try to stall.
I was able to get some work into my VE table today. I can not change the knock table while driving but even with the top 4 rows zeroed out I'm still getting code 36. By the time I'm done the whole table will be zeroed out. Theres got to be a better solution.
Old Jul 21, 2013 | 09:44 AM
efiguy's Avatar
So you were 100% right. Of course I was.
The top 4 rows are all high vacuum situations, you typically wouldn't need spark retard there any way. Go down 2 more rows.
Old Jul 21, 2013 | 09:52 AM
Transmission: t-56
Ok, stay posted. That will be my next change. As soon as I get a chance to drive it ill let you know.
Also, I noticed while tuning with a lot of the mid range light load cells in the ve table were increase from about .530 to almost .800 and in some spots almost .950. These are all in boosted regions. Is this normal. My strategy was to adjust the cells by using the 02 feedback correction, and to get it as close to zero as possible. Granted this is all street tuning so i know its no where near perfect but just wanted to know if these high numbers should be expected.
Thanks again. I have learned more in the past few days with your help then I have in the almost 7 years I have had the system.
Will
Old Jul 21, 2013 | 10:00 AM
efiguy's Avatar
Ok was it in light load or under boost? You said both.
Make sure your configuration screens are correct, I.e. injector size and fuel pressure.
Old Jul 21, 2013 | 10:13 AM
Transmission: t-56
Sorry for the confusion, I was tuning the light load cells, But had my driver tip into the throttle to get it up into boost and in different gears to get RPMs up I was getting a drastic o2 correction of 10 or more lean, so had to add quite a bit to the table in that range. Ive been meaning to double check my fuel pressure and adjust the regulator.
I currently have 36 lb injectors and think Its time to up the size. I think im just on the edge of them being adequate. If i calculated it right I should have around 47lbs.
Old Jul 21, 2013 | 10:40 AM
efiguy's Avatar
That's why your VE numbers are so high. I had a feeling you didn't have enough injector in it. What is your anticipated Hp?
Old Jul 21, 2013 | 10:50 AM
Transmission: t-56
Well is a purpose built for the super charger, 8:3:1 compression, stock bore and stroke 350ci, eddlebrock performer heads, and compucams cam 08-304-8, a stock configuration tpi thats been ported and with a 1000 cfm throttle body, all this runs out of a custom long tube header and duel exhaust. And of course the procharger running a 12lb pulley at the moment. This configuration must be good for at least 400-500hp id figure.
Old Jul 21, 2013 | 10:58 AM
efiguy's Avatar
If your pump will handle it up your pressure to 55-60. Then change the config screen.
Always use the smallest injector possible with the highest pressure. It'll drive better.
Old Jul 22, 2013 | 07:53 AM
Transmission: t-56
So I have an Aeromotive 11106 700HP EFI fuel pump. It can be run to a max pressure of 65psi. I need to get another gauge for my accel fuel pressure hose gauge. I took it off for something and now cant find it. lol
I have to ask, Why is it better to run a smaller injector with the higher pressure? Not that the injector I have is small, its just border line for my combo.
Old Jul 22, 2013 | 08:42 AM
efiguy's Avatar
Remember as you increase pump pressure you decrease it's output.
Normally a better spray pattern, better atomization of the fuel.
We were headed the EMC a couple years ago with a normally aspirated SB2 making 840hp using only 55# injectors.
Old Jul 22, 2013 | 11:59 AM
Transmission: t-56
So If I increase the pressure im going decrease the flow. Isnt that bad? Dont I need flow? What pressure would you suggest I start with. I still have to check where mine is but I seam to remember it being around 45-50psi. But just like everything else you told me to check Ive been wrong. lol
Old Jul 22, 2013 | 01:25 PM
efiguy's Avatar
All pumps are rated to supply a certain amount of fuel at a certain pressure. Some pumps will still work well above that but when you increase the pressure out of the pump to the injectors, the injectors will flow more, but the pump will pump less volume at the higher pressure. You need more flow out of the injectors so if the pump will still supply enough volume at the higher pressure then you're good to go.
Old Jul 23, 2013 | 07:58 AM
Transmission: t-56
Ok, So yesterday I was able to get a new gauge for my fuel pressure tester. My pressure was about 43psi at idle. since my pump can safely run up to 65psi I turned my pressure regulator up to 55psi. I then went into my calibration file and set the new fuel rail pressure. The car smoothed back out and my a/f returned to normal.
I also changed the cells in the knock table. Its been raining up here so I have not had a chance to test the changes yet. Ill let you know how it works out.
Thanks a million Mark. I wish there was a way to send you a beer for all the help you given me so far. Honestly I have learned more from you then anyone before on this stuff. Thanks again!
bamaboy0323
Sep 3, 2015 06:07 AM
db057
Aug 22, 2015 08:17 PM
marcusaw
Aug 10, 2015 08:13 AM
gwade12
Aug 8, 2015 08:17 AM
