89 bird VATS issue
Old Aug 5, 2013 | 01:30 PM
505 bird's Avatar
89 bird VATS issue
Sorry if this isn't in the right spot.
Hey all,
My uncle has a 89 bird that I'm trying to get running for him. The problem. I think is in the VATS, the car won't always start when it does you can't shut it off or it won't let you start it for approx 30min. He said him and a friend found a broken wire that they think went to the VATS, I haven't found the wire yet but I did ind a key that they tapped to the column. Can someone give me the knowledge to figure this out please. Maybe some troubleshooting tips. Any help would be greatly appreciated. Is there any way to completely bypass the VATS and just be don't with it?
Old Aug 5, 2013 | 01:36 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 89 bird VATS issue
depending on if this is tbi or tpi will determine Witch pin of the ecm receives the hz signal from the passkey to enable injector pulse. If you want it disabled completely I do reprograming and offer just vats removal as well send me a personal message.
Old Aug 5, 2013 | 01:56 PM
505 bird's Avatar
PM sent
Old Aug 6, 2013 | 08:52 AM
Engine: Lb9
Transmission: M20
I don't receive a pm, you can allways email me too @ brianlvs@yahoo.com
Street Lethal
Apr 30, 2019 12:14 PM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
greenyone
Sep 2, 2015 03:39 PM
djmarch
Aug 9, 2015 05:27 PM
