How to test a 165 ECM
Old Aug 14, 2013 | 09:18 PM
Hello, Michael's Avatar
Car: 1987 Pontiac Firebird Trans Am WS6
Engine: SBC 350
Axle/Gears: 3.70:1 BW M78 9-Bolt Posi
Is there a way to test the 165 ECM at the ALDL to see if its sending data? I'm ripping what's left of my hair out of my head trying to connect it to Datamaster. Is there anyway I can test it with a volt meter?
Old Aug 15, 2013 | 10:03 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: How to test a 165 ECM
The serial data line will put out between 2-5v koeo.
Old Aug 15, 2013 | 11:21 AM
Engine: SBC 350
I read on another post late last night that if you check the voltage at terminal E, it should fluctuate up and down. I checked and it was bouncing back and forth between about 3.25V and 4.80V. Is this just with the key in the run position and no resistor connected or anything?
Old Aug 15, 2013 | 11:57 AM
Engine: Lb9
Transmission: M20
Maybe the gm ecm guru Rbob will answer. As far as I know with out B having a 10k to ground the serial data out of E and it maybe tied to M will not send out the 160 baud data.
So I'm really not sure why voltage appears at E. But IIRC a reading of 2.5v or higher shows that there is some data flow. This is what I hate about the 165, it seems like there is some sort of revision with the 259 and 194 reman.
Old Aug 15, 2013 | 04:51 PM
Engine: SBC 350
I'm not sure if mine is the original or a reman. I'll have to look. I'm gonna guess it's the original.
KCG
Jun 24, 2020 04:33 AM
gta892000
Aug 11, 2019 11:16 AM
Johnoooooo
Sep 22, 2015 08:55 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
eustodp
Sep 20, 2015 05:09 PM
