msd prodata
Old Sep 7, 2013 | 01:07 AM
ervin's Avatar
msd prodata
HI GUYS.Left message in electric part.Thought I 'd try dfi and ecm.I bought MSD 6la programmable and down loaded 319 softwear.MSD dist.and bar two map,ready to program my timing peramaters.Imadgen my surprize when all I see is retard tables,RPM AND BOOST.No base timing tables.MSD is no help,guess I learned a lesson.Anyone tried this maybe could be of some help.ERVIN
Old Sep 8, 2013 | 04:11 PM
Cosmik Debris's Avatar
Re: msd prodata
Don't you just set your base timing in the normal way with the distributor and a timing light?
Old Sep 9, 2013 | 04:45 PM
ervin's Avatar
Re: msd prodata
Hi guys.TAlked MSD about my problem.They told me that it was not desighned to program tables of timing/map,yet they said on advertisement that you could program vac advance.LESSON LEARNED.They did tell me that if I knew what boost/retard was telling me ,I could simulate.WHAT?So on that note ,can any one tell me what 0 to 14.7 PSI is in inchs vacuum,or better yet what I understand,KPA.14.7 BEING 0 AT SEALEVEL.
Old Sep 9, 2013 | 04:48 PM
ervin's Avatar
Re: msd prodata
Sorry I forgot.They told me set base timing at max timing say 34 degrees.What ever.
Old Sep 9, 2013 | 05:10 PM
ervin's Avatar
Re: msd prodata
THIRD TIME IS THE CHARM.Talked Vic at MSD.He said that you plug in map sensor a red line will appear on the graph.Where it is will tell you what pressure is.You will still need a vacuum/boost gauge on car to figure where you are.Does anyone have inchs to KPA chart?What I do to put a supercharger on my car.
Old Sep 11, 2013 | 10:38 PM
ervin's Avatar
Re: msd prodata
TALKED TO HOLLEY they said it won't work with HP.GUESS it won't work with stock ECU either.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
sreZ28
Oct 22, 2015 08:21 AM
meeklay812
Oct 1, 2015 03:46 PM
86CamaroDan
Sep 29, 2015 10:08 PM
