165 ecm wont connect to tuner pro
Old Sep 23, 2013 | 09:18 PM
GreekItalianMan's Avatar
Car: 1986 Trans Am
Engine: lb9 305 tpi
Transmission: THM700R4
Axle/Gears: Posi-rear,3.27 9 bolt Borg Warner
Hi Guys, I have read the stickies and have started to datalog, I hav ethe proper bin files and tables for my 86 tpi trans am, but I can not get to read the data from the ecm, itll just keep saying not connected, yet when I went to read my friends 88 gta i connected with one try. I have the proper mask 32b for my vehicle loaded on it too....
Old Sep 24, 2013 | 10:59 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 165 ecm wont connect to tuner pro
Unfortunately this is all too common with the '7165 ECMs. Need a different one.
RBob.
Old Sep 24, 2013 | 12:31 PM
Car: 1986 Trans Am
Engine: lb9 305 tpi
Different ECM? I need to data log because I'm getting a code 44 and I can't fix the problem without knowing wtf is going on with the ECM
Old Sep 24, 2013 | 01:13 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes, a different ECM.
RBob.
86CamaroDan
Sep 29, 2015 10:08 PM
Strick1
Sep 6, 2015 10:38 AM
scotrans am
Sep 5, 2015 04:26 AM
85Special
Sep 3, 2015 04:21 PM
andy74
Sep 3, 2015 08:41 AM
