92 vin e to 88 vin f ecm
Old Sep 17, 2013 | 04:59 PM
Youngs92's Avatar
Car: 1992 Camaro RS
Engine: 5.0L TPI
Transmission: 5-speed
My car came from the factory as a 92 305 tbi. Previous owner began the conversion to tpi using 88 parts. The car was rewired using a painless performance harness for 86-89 tpi. Car has been running poorly and our mechanic thought it might be having the 92 ecm still in the car. I happen to have an 88 vin f ecm number 1227165. Can I simply swap the 92 ecm with the 88?
Old Sep 18, 2013 | 08:41 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 92 vin e to 88 vin f ecm
Since it is the correct harness for the '88 '7165 ECM. Plug it in and try it.
Also, it only takes a minute to see which ECM is in the car now.
RBob.
Old Sep 24, 2013 | 04:54 PM
Youngs92's Avatar
Car: 1992 Camaro RS
Engine: 5.0L TPI
Thanks Rbob. I put the 88 ecm in and so far it seems to be running okay. I did get code 24, which is telling me there is no signal from the vss, but my speedometer is working and working well so I'm going to disregard this for now.
Old Sep 24, 2013 | 05:57 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I can't recall whom posted this, but if code 24 occurs while the wheels aren't moving, ignore it. It has to do with rev'ing and holding the throttle open while at a stand still. If that is when the SES & code 24 occur, not real.
If it does occur while moving the VSS buffer under the dash cluster may be bad.
OTOH, the '92 TBI car uses the under-dash VSS buffer. While an '88 Camaro uses a dash cluster VSS buffer. A '88 TPI Firebird may also use the under dash buffer. Not sure.
RBob.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
