how do I fix codes
Old Oct 6, 2013 | 08:20 PM
ajhdlh77's Avatar
Car: 92 firebird
Engine: 3.1 v6
how do I fix codes
I need help on fixing code 33 & 43 on my 92 Pontiac firebird 3.1 v6. I also would like any ideas on why my car will start and idle but die when the gas is applied. I have replaced the IAC, the MAPS, TPS, timing chain , distributor, cap and rotor, plus, wires, fuel filter, and knock sensor. That's all I can think of right now.
Old Oct 6, 2013 | 08:34 PM
BlueWrath92's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: 10 Bolt 3.42 Posi
Re: how do I fix codes
Maybe bad Timing? Maybe Bad Distributor Shaft? could be alot of things... did you disconnect your battery after you attempted to fix codes to reset them?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
gta892000
Aug 11, 2019 11:16 AM
BumpaD82
Feb 26, 2016 02:57 PM
64Chief
Sep 12, 2015 08:05 AM
