help accel gen 6
Old Dec 17, 2013 | 06:40 AM
heimedw's Avatar
help accel gen 6
I have a bbc 402 that im putting a supper ram system on. The first question is I know that in closed loop the system wants to run the engine at a afr of 14:7:1. I think that it will be to lean for my engine setup. I think that idle will be more like 14:2:1 cruise 14:0:1 and wot 12:5:1. The question is can you get a good tune running in open loop? Or is it better to run closed loop and just set wot open loop very low? 40%? Im new to this so I hope that these question don't sound dumb. Thanks
Old Dec 17, 2013 | 11:14 AM
Ronny's Avatar
Re: help accel gen 6
That question may be specific for Accel 6. Dont they have their own forum/tech line?
I dont see why you cannot command CL for alternative A/F ratios? Within reason...
Old Dec 17, 2013 | 06:42 PM
efiguy's Avatar
You should be able to change the values to something other than 14.7:1.
But it will only accept a narrow band signal so anything outside of 14.0-15.0:1 is meaningless.
As described on EFI 101 use a wideband that also supplies a narrow band signal. The Accel DFI 77062 will do that. That'll be the best way to tune that system by far.
Old Dec 18, 2013 | 06:41 AM
heimedw's Avatar
efiguy is the kit 77062 compatible with the gen 6? Also is it a plug and play or does it have to be hardwired to the gen 6 harness? Or is it a stand alone program?
Old Dec 18, 2013 | 07:03 AM
efiguy's Avatar
Originally Posted by heimedw
efiguy is the kit 77062 compatible with the gen 6? Also is it a plug and play or does it have to be hardwired to the gen 6 harness? Or is it a stand also program?
It's pretty much plug n play. It will supply a narrow band signal to the Gen 6 while giving you an actual air/fuel either by a gauge or laptop. It will not make any corrections however. You will have to enter the values yourself.
tazs2000
Jul 15, 2017 08:44 AM
evilstuie
Feb 28, 2016 03:33 PM
BAMiller
Sep 14, 2015 06:38 PM
hydrolic144
Aug 29, 2015 04:14 PM
355tpipickup
Alternative Port EFI Intakes
Aug 26, 2015 04:08 PM
