Help Deciding which ecu to run.
Old Dec 30, 2013 | 09:25 PM
dellman83Z's Avatar
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
I am currently running c950 on my supercharged 383. Looking to upgrade with efi connections components, crank cam sensors and lsx coils. I am just torn as to which system I want to control it with. I either want to use hp efi because of the self correcting fuel map which would be nice considering coming from the c950. There is a off idle lean issue I just could never get rid of and very annoying. Which leads me to the other option. HP tuners and a ls1 computer. Its a steep learning curve to learn, but it opens the door to having a pro tune it if I cannot get it right. Cost wise for me is about the same, so its really a non issue there. Just really torn which way to go here and I know everyone on here is very helpful so thanks ahead of time.
Old Dec 31, 2013 | 04:13 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Help Deciding which ecu to run.
EBL P4 from dynamic efi.com
Old Jan 1, 2014 | 08:27 PM
dellman83Z's Avatar
ebl isnt bad at all. Just wont do what I want to do.
Linson
Oct 24, 2025 02:00 PM
RS Reaper
Oct 17, 2018 07:52 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
KO1
16
Oct 15, 2015 05:00 PM
aaron7
Sep 30, 2015 09:15 AM
