Can You Identify These ECM's/MemCals
Old Mar 3, 2014 | 01:58 AM
CALIROCZ28's Avatar
Car: '98 Z28 LS1
Transmission: 4l60E
Axle/Gears: 373
Hi everyone, I inherited a bunch of GM parts from a relative who recently passed away and I have about 8 GM ECM's that I have no idea except for 1 what vehicle they are for. I also have 5 new MemCal modules/chips that I would like info as to what vehicle or motor they would work in.
Can anyone identify any of these ECM numbers and match them to a vehicle?
01227727 - has 4 Yellow sockets and uses a MemCal chip (No MemCal in it)
16198259
16188262
16236965
1226870
01228322
01226867
01228062
What numbers on the MemCal's are relative? Example of one of the chips
Blue cover over Black socket Number on side 68767 95178 3
Under the Blue shield AMSK 1614 0338
Blue Cover over Brown Socket 63767-92
on the chip under blue cover Delco 4894 4894
Delco 6027 BDFS 2272949
So if someone has documentation on these parts or can direct me in the right direction I would appreciate the help.
Thanks!
Old Mar 3, 2014 | 09:00 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: Can You Identify These ECM's/MemCals
1227727 is an underhood ECM, found most commonly in W-body cars, andearly '90s Corvettes.
16198259 is an updated version of the 1227165. Commonly found in late '80s F-bodies and Corvettes
1226870 is '85 to '86 MPFI V6 (2.8L) and TPI V8
1228063 is 88 to 93 TBI V6.
BDFS is 1993 5.0L automatic
That's all I can find.
Old Mar 3, 2014 | 09:03 AM
Ransford2987's Avatar
Car: 1990 IROC-Z/1980 Firebird
Engine: 5.7 TPI
Check this site out and see if it helps. http://www.3rdgenformula.com/90/promcodes.htm
Old Mar 3, 2014 | 06:58 PM
CALIROCZ28's Avatar
Car: '98 Z28 LS1
Transmission: 4l60E
Axle/Gears: 373
Six Shooter thank you much for that info, much appreciated.
Old Mar 3, 2014 | 07:23 PM
CALIROCZ28's Avatar
Car: '98 Z28 LS1
Transmission: 4l60E
Axle/Gears: 373
Ransford thanks that link was very educational.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
