need help with ecm
Old May 13, 2014 | 11:13 PM
9588camaro's Avatar
Car: 88 camaro iroc
Engine: 355 tpi
Transmission: 700 r4
need help with ecm
swapping out the cam and heads on my tuned port. I don't want to dig into it until I can find someone to tune my ecm or help me tune it. So anyone out there in the northwest ohio area that has the equipment and knowledge to help me out? thanks
Old May 14, 2014 | 08:04 AM
oddscrounger's Avatar
Car: 1987 IROC Z28
Transmission: TKO 600
Axle/Gears: 3.45 (G92 package)
Re: need help with ecm
I think you'll be ok because the computer will re-learn as best as it can to adjust to the changes but eventually you'll want to find someone to fine tune it. I happen to have a buddy here in Chicago who has all the equipment to tune OBD1 cars and flash his own chips, but good luck, there aren't many...
Lots on this site, but only if they're close to you and willing to hook up to your car and drive it around for 8 hours, or on a dyno...
Don't buy any custom chips through mail... there's no way for someone to flash a chip for your z28 from across the country that will work best. Even if you give them all the specs they'll basically be guessing at what "should" improve our performance...
Old May 14, 2014 | 10:40 PM
9588camaro's Avatar
Car: 88 camaro iroc
Engine: 355 tpi
Thanks for the info.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
