Prom confusion with engine swap
Old Jul 9, 2014 | 12:00 PM
ccmctech's Avatar
From: Murfreesboro, TN 25 miles Southeast of Nashville, TN
Car: 1988 Pontiac Firebird Trans Am
Engine: Was a 305 TPI swapped to a 350 TPI.
Transmission: 700 R4
Axle/Gears: 2.73 I think.
First, let me thank all of you for the information on this site. It has helped me greatly. I am swapping the engine in a 88 305 TPI trans am to a 350 TPI. I have everything the site has recommended to do with the swap, thanks again. The prom I removed from the car is a AKFN 2178, I purchased a APYU 3516 to install in the exsisting ecm. I am removing the smog system, deleting the 9th injector, shorty headers with a 3" cat back exhaust, everything else will be stock. I will use the exsisting cat converter. Will the prom APYU 3516 install with no other programming needed?
Old Jul 9, 2014 | 12:20 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Prom confusion with engine swap
I'm not sure, but APYU likely has VATs enabled. If your car doesn't have VATs, the injectors will never be fired.
There is a slim possibility that the fan(s) may work in reverse. That is on when commanded off, and off when commanded on. This is something that just needs to be tried to find out.
RBob.
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
Sanjay
Aug 12, 2015 03:41 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
