is there anyone who can test ecm's and prom's?
Old Jul 12, 2014 | 11:39 PM
92crimsonRS's Avatar
Car: 89 trans am GTA
Engine: 355
my mil is not doing the initial handshake blink when i first turn the key on. iac counts are stuck at 160 o2 reads pig rich no matter what (plugged in or not). blm's stay at 128 yet it smells rich an goes through 2 gals in 5 miles.
replaced every sensor brand new motor. checked all grounds even added a few.
im at wits end with this car.
Old Nov 10, 2014 | 02:28 PM
kingbowl93's Avatar
Re: is there anyone who can test ecm's and prom's?
It could definitely be your ECM and or Prom
Old Nov 11, 2014 | 07:54 AM
ULTM8Z's Avatar
Check the inputs to the ECM first before replacing it.
Based on your username I assume you have a 92 which would be a 7730 ECM.
http://chevythunder.com/fuel%20injec...20(ecm#1227730)
Old Nov 14, 2014 | 01:40 PM
L98_383_Stroker's Avatar
BLMs might stay at 128 if open loop. Have you checked your plugs? Do they all look rich, or just a few? Are you going into closed loop? It sounds like you are scanning it; does everything look good?
F.I. 57 Belair
Aug 23, 2021 01:09 AM
gta892000
Aug 11, 2019 11:16 AM
skeltor
Feb 2, 2016 10:37 AM
Johnoooooo
Sep 22, 2015 08:55 AM
eustodp
Sep 20, 2015 05:09 PM
