acceleration
Old Aug 11, 2014 | 02:03 PM
Koolaid Camaro's Avatar
acceleration
First off, if this is in the wrong forum I am sorry not sure where to post this. I have a 92 Camaro rs with the 305 that I am trying to build into a drag car. I have removed the smog pump, the a/c, the knock sensor, added a Jet stage 2 chip, and hooker headers as well. The problem I am getting is when I accelerate when the car gets to 3000 rpms the tach goes to 0 and back fires, accelerates back to 3000 to 0 and back fires and repeats. I have played with the timing and can get it a little better, but the problem persists. If this right is there any advice you can give? If not what board should I be on or is there any more info you need?
Thank you in advance,
Koolaid
Old Aug 11, 2014 | 03:20 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: acceleration
Does it do it without the Jet Chip?
Also why did you remove the knock sensor?
Old Aug 11, 2014 | 07:09 PM
Re: acceleration
I plugged the stock chip back in and it ran fine . I removed the knock sensor because it broke when installing the headers. We wanted to the performance out of the Jet chip, any ideas?
Old Aug 11, 2014 | 07:49 PM
midias's Avatar
Re: acceleration
reinstall a new knock sensor.
Then try the jet chip although the jet chip may not help
Pac J
May 17, 2020 10:44 AM
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
ULTM8Z
Sep 16, 2015 09:15 AM
