Camaro 85 code 23 problem
Hi guys I have a camaro 85 iroc I have code 23 what is the sensor on the intake I replaced and chek engine keeps coming on when stop light comes on and when I star driving the light come on and the car shakes a lil bit and pumpin like is starving of fuel I desconnet the battery reset it and drive it and light comes on and some one told me the ecm is the one can be faulty or the m/c solenoide where is that located is a fuel injection 305
Please help I put new intake air sensor
Car: check
Engine: check
Transmission: check
Re: Camaro 85 code 23 problem
The MAT sensor is located on the bottom of the plenum near the rear. The code 23 is due to an open sensor, open wiring, or a bad ECM.
The sensor wiring goes to ground (ties in with the TPS & CTS grounds), with the other wire going to pin A11 at the ECM.
At room temperature measure the resistance between ECM pin A11 and the ECM case. It should be about 3200 ohms.
RBob.
RBob.
Ok I order a ECM and the one I have I have the problem that the green wire that goes to the fuel pump relay is not working I trace the wire to the ecm and there is no power coming out of the ECM so I put the MAT sensor and keeps doing the same think and also my electric fan when I put the key in on position is running continuos and never stops so I put a new cooling fan switch a new alectric fan motor and also put new relay also I put the fuel pump relay new and I'm thinking the ECM transistor is no good so I'm waiting for my ECM to arrive to put that and see if problem stops Bc before that the car was working fine so after the fuel pump stop working Bc the relay is not getting power so I'm more then sure all this problems is Bc the ECM failure
Car: check
Engine: check
Transmission: check
M/C solenoids are on carb'd set ups, not EFI. This is a TPI set up?
No power to FP relay coil, this is driven by a small transistor in the ECM. Common for them to pop and easy to replace.
RBob.
RBob.
Hi i open my ECM yesterday and i found my ECM is burn and i Will like to know if is There is some Good place to send it and get it repair or is not recommended to try to fix it thank you
Car: check
Engine: check
Transmission: check
Can you post a decent picture of the burnt area, it may or may not be fixable. And if it is a quad-driver, need to find the bad relay or solenoid that caused it. Otherwise the next ECM will meet the same fate.
RBob.
RBob.
92camaroJoe
Aug 13, 2015 06:07 AM
