ECM Terminal Voltage
Old Nov 18, 2014 | 11:43 AM
Sonny_T's Avatar
Car: Transam, 85
Engine: 305 HO, 4bbl Carb, G Engine
Transmission: 5 Speed
In the shop service manual, at page 6E1-11 (and like) it shows voltage
chart in each pin.
Question is, how do you measure voltage at pin. Do you disconnect it from ecm, turn key on, then take ground lead of voltmeter to a ground pin of connector, and other lead to each pin to find voltage........
or
Both connectors stay connected to ECM, turnk key on and you do what ?????
Assuming MC solenoids get 12 volt on both side per chart and diagram, how does it click when you turn key on
Old Nov 18, 2014 | 01:11 PM
ULTM8Z's Avatar
Re: ECM Terminal Voltage
chart in each pin.
or
Take the colored the locking tabs off the backs of the connectors so you can access the the pins on the harness. You'll probably have to disconnect the ECM from the harness to do this.
Then plug the connectors back in to ECM.
Use a digital voltmeter to probe the terminals from the backs of the ECM connectors. The other probe goes to ground (but get it to battery ground). Some tests required the key on, others require the engine running....
Old Nov 18, 2014 | 02:08 PM
Sonny_T's Avatar
Car: Transam, 85
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
