Datalogging parameter questions
Old Dec 13, 2014 | 12:24 PM
db1989iroc's Avatar
Hey guys,
I just put together a 5.7 TPI with a zz4 cam. I am in the process of working out all of the bugs as the wiring harness was a mess from prior owner. I am using tuner pro RT to datalog and was wondering if anyone could see if anything looks out of whack. I know the usual parameters like TPS etc. The mass air gm/sec seems high, could be the cam?The car is running rough, hunts at idle and seems to have a miss. I also get shuttering when the torque converter locks up. When it is cold i get a code 36 and sometimes a code 33 along with it. I put up a screen shot of when the car was idling in the 800-900 range, I bumped the idle down to 650-700 and the second and third screen shot shows that. I really would appreciate any assistance as I am brand new to using datalogging. Thanks in advance for any input.
Attached Thumbnails Datalogging parameter questions-photo-1-4.jpg   Datalogging parameter questions-photo-3-3.jpg   Datalogging parameter questions-photo-4.jpg
Old Dec 16, 2014 | 09:23 AM
Keoman's Avatar
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
Re: Datalogging parameter questions
gotta set some time aside for reading now.
sounds like you are in the neighborhood of chapter 5.
https://www.thirdgen.org/forums/diy-...uide-book.html
CORV3TT3
Aug 23, 2015 11:26 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
