L69 Trouble Code 41
Old Mar 21, 2015 | 07:10 PM
Travas's Avatar
Car: 1983 Camaro Z28HO
Engine: 305ci 5.0L L69
Transmission: Borg/Warner T5
Axle/Gears: 9 Bolt 3.73 gears
L69 Trouble Code 41
Hey all, I have a 1983 Z28 L69. I keep getting the code 41 which is 1x Reference which means that the ECM is not getting a signal from the Distributer. I can start the car and it will run if i play with the gas pedal but when i take my foot off the gas it dies. No sputtering just dies. I have replaced my Computer, Ignition Control Module, Cap, Rotor, Plugs, and Wires. I have gone through and checked all the grounds on the body and block and they are all good. No broken or cracked wires and all my fuses are good. Still can not get the car to start. Almost everything is new. I just rebuilt the engine about 9 months ago and its been running great sense then. Even the carb is new (QJet). I was driving the car pretty fast then went to slow down and the thing almost died on me. Got it going again then pulled in my driveway and it would not start after that. Obviously im missing something......HELP!!!!!
Old Mar 22, 2015 | 12:57 AM
driveability's Avatar
Re: L69 Trouble Code 41
I worked as a Tune up and drive-ability tech when these car came out. I had one just like this and it was the PROM inside the PCM.
Old Mar 26, 2015 | 06:18 PM
Travas's Avatar
Ok thank you very much. That is what a couple other people have told me.
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Dec 5, 2015 09:22 AM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
Lmancha96
Sep 25, 2015 08:11 PM
