ecm and vats question
Old Mar 31, 2015 | 04:06 AM
shadowbird's Avatar
Car: 88 firebird mutt, 89 camaro rs
Engine: 305 tbi
Transmission: Firebird:700r4 Camaro:T5
Axle/Gears: stock(unknown)
I was recently given a 1989 camaro rs with a 305 5spd that is missing the vats chipped ignition key, the cars in great shape and I was hoping to get it on the road and use my 1988 firebird 305 auto for parts, I was wondering if the ecm from my firebird will work in the camaro, and if so, will that in turn bypass the vats?
Old Mar 31, 2015 | 07:19 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: ecm and vats question
If your car has the VATS still enabled, and you don't have the right chipped key, it will never start or run. You have to get the right key for the key cylinder. Changing the computer will do no good.
Look up VATS bypass in the search box. There is many procedures on how to do this.
Or, have the chip reprogrammed for VATS disabled.
On another note......finish your profile.
Old Mar 31, 2015 | 12:17 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
If both cars are TBI the '88 ECM will work in your '89.
RBob.
Old Apr 1, 2015 | 02:21 AM
shadowbird's Avatar
Engine: 305 tbi
I did look up the bypass setups, but I cant afford to buy a new eprom, I was hoping the non vats 88 comp would do the trick is all. both tbi by the way
stalkier
Dec 6, 2015 11:25 PM
Jae992
Aug 27, 2015 09:07 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
stalkier
Aug 13, 2015 12:59 PM
