Fuel specs
Old Sep 5, 2001 | 10:00 AM
raven350's Avatar
Car: '89 Pontiac Firebird
Engine: 5.7L
Axle/Gears: 10-bolt w/ 4.10 and Eaton Posi
Fuel specs
Okay, I just got my diagnostic scan tool and my laptop.
I am trying to figure out what the:
Block learn cell number,
Block learn muptiplier,
Integrator,
Injector pulse width
are suppose to be. generally speaking of course.
Trying to figure out if the prom chip is burned correctly or if I need to invest in doing another one.
Any help would be much appretiated.
13.3 @ 100.3MPH 95 degrees and 95% humidity w/ no tuning on motor
Sportsman II, Gear drive, Perf. Res. chip, SLP 1 3/4" headers, Edelbrock muffler, Trans-go stage 3, Vigilante 9.5", Functional Ram Air hood, SLP roller cam, 24lb ADS injectors, AFPR, 3.45 gears, Stealth intake, 58mm setup, Spohn suspension, and other goodies...
raven
Custom EFI Intake Setup
Old Sep 5, 2001 | 07:44 PM
hectorsn's Avatar
Car: 78 Regal
Engine: 82 FBod LG4 305, 730 ECM
Transmission: M20
Axle/Gears: 4.10
I'll take a stab at this. BLM and INT is optimum at 128. Anything over and the ecm is adding fuel and vice versa on either BLM or INT. BLM cell will vary by what load (or g/s), rpm you're in. Really doesn't matter much in the real world what cell if BLM is always 128. Oh yeah, at WOT ecm goes into open loop so no BLM correction, it's at 128. Inj PW can vary a bunch. At idle more than 2 and less than 5ms is acceptable but by no means a rule. At WOT (depending on RPM?), 20ms I believe is lock up. General answers to a general questions. I don't know if this thread belongs here though. You never mentioned it but it sounds like you have a GM ecm and the answers I gave were for one. It also sounded to me like it has a bought prom and not owner tuned. This board is more for aftermarket ecms. If you decide to take it to the DIY prom board don't bother asking if it would be worth burning your own prom as the answer will always be, "YES". Either way, GM or aftermarket, you have the best mean of tuning your own car. No one is going to want it as perfect as you, even if they're getting paid for it.
[This message has been edited by hectorsn (edited September 05, 2001).]
Mickeyruder
Sep 2, 2015 02:45 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
theurge
Aug 21, 2015 12:46 PM
80s Poncho
Aug 19, 2015 06:45 PM
Electro_X
Aug 19, 2015 07:59 AM
