EBL? P4?
Old May 12, 2015 | 01:23 PM
85Special's Avatar
Car: Silver 1985 IROC-Z
Transmission: 700-R4
EBL? P4?
Ok so I have a frankencamarro 85, with 87 ECM and MAF sporting a 350 v8... Yea you guessed it, MAF problems. I also have the one year HEI computer advance distributor for the 85 305 v8. It's the screw down, coil in cap, HEI.
So I need to pull the trigger here and dump this damned MAF system. Not even orileys sells a good MAF now. I need to keep the egr system and evap so I figure EBL is the way to go. Was told I needed an EBL P4, looked it up and I'm thinking the EBL would be an easier swap... And save me a few bucks.
My only intension with this car is to have a dependable daily driver with some guts. I may do a few mods down the road but nothing insane.
Anyway if I'm understanding what I'm reading the EBL is 85-89 ECM harness, and the EBL p4 is 90-92 ECM harness. I'm just trying to sort through all the info to figure out what I need to get this project in motion.
Old May 12, 2015 | 02:00 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: EBL? P4?
If you don't think repinning your harness is a good idea for a weekend project.
Look for a 90-92 tpi sd harness and repin c100 or rework a tpi maf harness so your ready to do the swap easier.
Old May 12, 2015 | 02:24 PM
85Special's Avatar
Re: EBL? P4?
That hits on my main question, I suppose I danced around it but never really asked.
EBL - uses 85-89 ECM harness and utilizes MAF wires to connect MAP sensor. Likely a 2 hour swap... If I'm drunk lol.
EBL P4 - uses 90-92 harness, either a full rewire or new ECM harness would be needed. Better clear a weekend.
Is the EBL really that easy? A new map sensor and a little wiring? Is the p4 worth the expense of a harness or wiring time? Am I completely wrong about something?
Old May 12, 2015 | 02:29 PM
Engine: Lb9
Transmission: M20
Re: EBL? P4?
Faster processor speed, ease of tuning. I would say if you have done many engine modifications yes that's the way to go. If your looking for just a ECM upgrade better calibrations and faster processor do the 870 to 165 conversion and use a 89 f-body tune like AUJM if you still have cast iron heads.
Old May 12, 2015 | 03:22 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: EBL? P4?
I tend to push folks with the '85 - '89 TPI set ups to the EBL Flash with the Port Mod. There is a lot less re-pinning to do over the EBL P4 system.
Along with the EBL Flash ECM having the same form factor as the stock ECM. Note that the burn-off module can also go-away.
RBob.
Old May 12, 2015 | 03:25 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: EBL? P4?
lol... yes, it is that easy.
Old May 12, 2015 | 03:48 PM
85Special's Avatar
Re: EBL? P4?
350 v8
Late 70's smog heads (888's I think) iron
85 305 tpi hydrolic flat cam
Hooker block hugger headers
1 wire to 3 wire O2 sensor swap
2 3/4 exhaust w magnaflow cat.
K&N air filters in stock air box
Nothing really special
Old May 12, 2015 | 04:06 PM
85Special's Avatar
Re: EBL? P4?
Damn, I'll be ordering the EBL soon ��
antman89iroc
36
Jan 31, 2016 08:42 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
Quzyle
Oct 15, 2015 03:35 PM
92rsvortec350
Sep 16, 2015 09:12 AM
85Special
Sep 3, 2015 04:21 PM
