Help with OTC 2000! Anybody else have one that can answer a question?
Old Oct 9, 2001 | 08:01 PM
Chris Sartori's Avatar
Hi All,
A friend of mine sold me his old OTC 2000 monitor. It has one cartridge with it that covers GM,Chrysler and Ford up to 89. I just changed my 88 TBI to a 91 TPI system and wanted to use the scanner (monitor) to check out the 7730 ecm and the system. My friend told me it should read the 91 systems but all I get is "+ no data" when trying to access the ecm and system. Anybody have any thought or ideas? I have been looking for the GM cartridge that goes up to 91 or 92, but nobody has it.
Thanks,
Chris
Old Oct 9, 2001 | 10:00 PM
chevymad's Avatar
Car: 87 Formula
Engine: 327
Some of the tpi systems require a different cable adapter for the otcs to work. I think our otc is a 4000 enhanced and it has two cable adapters, one standard and one tpi only. Not all tpi cars require the tpi adapter though. The machine even tells you that "tpi adapter may be required" So they dont even know when you'll need it.
I think this is probably your problem beings your getting the "no data" message. When I've tried the wrong adapter I've recieved the same message.
Frozer!!!
Jan 19, 2024 04:55 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
