TPS only 4.3 volts at WOT
Old Nov 23, 2001 | 07:58 PM
MARKT111's Avatar
Car: 1989 TTA
Engine: 3.8 Turbo
Transmission: 200R4
my TPS only goes to 4.3 volts at WOT.(glad I finally got a scanner)and thats with my floor mat out,was 4.15 with it,and thats really leaning on the petal like I don't think I should have to.At what voltage does the ECM see full throttle??and where can I find a list of where all my values should be??
89 FORMULA 350,WS6 SUSPENSION,HOTCHKIS STB,KONI REDS,WONDERBAR,SLP REAR CONTROL ARMS/PANHARD,POLY BUSHINGS,FRESH 355 MOTOR,TCI 12" STREETFIGHTER,TRANSGO SHIFT KIT,3.70 GEARS,FLOWMASTER EXHAUAST,SLP 1 3/4 HEADERS,NO CATS,58 MM BBK,MINIRAM INTAKE,COLD AIR,ALL FREE MODS
Old Nov 23, 2001 | 08:08 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
There is a table in the eprom that you can set at what %TPS the engine goes into Power Enrichment (the ECM's term for WOT).
This %TPS varies over various RPMs but for most cars, the ECM is in PE/WOT @ 70% TPS.
I personally like setting the %TPS to engage PE a little lower. Depending on the RPM range, I engage PE from 65% (lower rpm) to 45% (higher rpm).
Right now, your TPS sounds about normal. Don't believe this BS that you need 4.5+ volts to engage PE. It just isn't true. It's completely conrolled in the eprom and if you want to change it, that is the place.
Old Nov 24, 2001 | 02:20 PM
MARKT111's Avatar
Car: 1989 TTA
Engine: 3.8 Turbo
Transmission: 200R4
thankyou,but where can I find what my other values should be?how much knock before timing retard?MAF readings etc,,,,,
Old Nov 25, 2001 | 02:18 PM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
The factory specs call for .54@idle and 4.49@wot with a =or- .07volts.
D&Z Performance
"Putting Power to the Pavement"
RS Reaper
Oct 17, 2018 07:52 PM
racereese
Oct 3, 2015 03:46 PM
