ECM code reader
Old Nov 23, 2001 | 03:27 PM
88camaro's Avatar
ECM code reader
Does anyone know how can i make an ECM code reader ???
Old Nov 23, 2001 | 03:36 PM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
Do you want to read the trouble codes off the ALDL? I have not seen a DIY code reader. It's pretty simple just looking at them.
Old Nov 23, 2001 | 06:58 PM
88camaro's Avatar
how do u do that ?
Old Nov 24, 2001 | 12:04 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Take a paper clip and place it between the the two upper pins at the right side ( A-B )then turn on the ignition ( not start ) and the SES light will flash: flash, pause, flash-flash, long pause flash, pause, flash-flash, long pause flash, pause, flash-flash, long pause.After this "12" code repeating three times the "real" error codes come .
GTA -89:383, 4-bolt,Free flow muffler,dual 3" HF cats, Edelbrock headers, Canfield heads, 1.52 RR 7/16, ZZ-9 cam, Big Mouth, AS&M LTR, !plenum, 52 TB, MSD 6AL, TPIS level V prom, Superior shift-kit and all the minor mods,looking for a SR ...
http://www.itv.se/tacs/members_cars/m279/m279.html (Swedish Trans Am Club)
Old Nov 24, 2001 | 04:51 PM
88camaro's Avatar
so a long flash = 10
and a short one = 1
Old Nov 26, 2001 | 07:42 AM
RCR's Avatar
RCR
88': No, The long pause seperates the individual codes. The first set of flashes is the tens digit. The second set of flashes is the ones digit. Long pause seperates the codes. All flashes are the same length.
Old Nov 26, 2001 | 05:31 PM
88camaro's Avatar
hum....ok, although the first one appears to be longer...
that means the car is just giving off code 12 which means everything's ok
then how do u explain my problems
(they are listed in both thirdgen sec, and v6 sec, under the topic FIELD SERVICE MODE RESULTS)
please read, and tell me what ya think
85 Jimmy
Sep 30, 2015 07:56 AM
Formula8r89
Sep 22, 2015 04:24 PM
eustodp
Sep 20, 2015 05:09 PM
Reese-J
Sep 14, 2015 02:43 PM
RyanJB
Sep 2, 2015 01:27 PM
