88 tpi in 90 tbi swap
Old Jun 3, 2015 | 11:25 PM
scott j's Avatar
Car: 90 camaro rs
Engine: 5.7 tpi
Transmission: t-5
Axle/Gears: 373
I have an issue with power to fuel pump. I have repined bulk c100 connector. and looks like I still have e6 orange wire 0n 88 pinout that needs power. what should I do? cranks with jumping starter relay only.no power to fuel relay.
Old Jun 4, 2015 | 01:54 PM
bigal55's Avatar
Car: 88 convertible
Engine: 5.7L
Transmission: 4+3 maual
Axle/Gears: 3.07
Re: 88 tpi in 90 tbi swap
You need to supply a lot more information. What harness are you using? What ECU are you using? VATS? Using MAF TPI in a 90? Keeping the MAF? 2 problems, won't crank and no power to fuel pump? BTW, did you change the fuel pump to a high pressure TPI pump? Give as much info as you can.
Never mind, I see this is a double post.
Old Jun 5, 2015 | 12:04 AM
scott j's Avatar
Car: 90 camaro rs
Engine: 5.7 tpi
Transmission: t-5
Axle/Gears: 373
Hey, just got it fired up for first time. Purring like a kitten
It was orange wire powering fiel relay. Orange wire from 88 to 90 body c100 was open
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
InfinityShade
Aug 22, 2015 08:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
