Need another ecm
Old Dec 12, 2001 | 07:16 PM
thatsme's Avatar
Need another ecm
I have 90 fb with a 3.1 is there any other car i can get an ecm out of.
Old Dec 13, 2001 | 03:30 PM
Redi2RocZ's Avatar
Car: '86 IROC Z
Engine: 305 Tpi
Try looking at the Tech Articles - Electrical - ECM Interchange section of this websites Home Page
Try eBay for a used replacement if you can't get one from a wreckers yard
1986 IROC Z 305 Tpi Auto Stock
1987 Ur quattro Turbo
1989 200 quattro Turbo
Old Dec 13, 2001 | 10:22 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Check yours, you SHOULD be '7730 but sometimes there is different. The '7730 was used on TPI F-bodies along with a TON of 3.1 V6 cars (except W-bodies). Go to a wrecking yard, look for early 90s 3.1s and check the VIN for the 4th digit. As long as the 4th digit doesn't say "W", you will be okay.
Cavaliers are the most numerous and easiest to spot between 3.1s and 2.8s. 2.8s use MAF and won't work.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
