MegaSquirt on 91 TPI
Old Sep 10, 2015 | 09:28 AM
  #51
kurtis72's Avatar
Car: 83 & 91 Z28 + others
Engine: l69 & lb9
Transmission: t-5
Re: MegaSquirt on 91 TPI
Since my factory ECU has the knock module built in I don't know if an external GM unit would be compatible with my sensor. There are several part numbers, not sure which one would work if any.
I plan to write up some docs for people who want to use MS on their TPI, either in the stock F/Y Body or in a swap. Hopefully I can list exactly what to do right the first time so they don't have to spend as much time as it has taken me...
Old Sep 10, 2015 | 10:06 AM
  #52
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
http://www.megamanual.com/ms2/knock.htm
Not sure what wells # your factory knock sensor is, but that article should help.
I did that a couple years ago, but I based it on the Microsquirt MODULE.
http://www.microsquirtmodule.com/
I stuck it inside a stock '165 ECM case, and developed the wiring schematic so it mimics 90% of the factory wiring for plug and play. The only thing you have to do is unplug the maf, and wire in a MAP sensor.
http://members.cisdi.com/~anesthes/p...om/megasquirt/
I even have starter project files for a stock L98.
But everyone wants to buy a pre-built MS2 and do it the hard way
The Microsquirt MODULE is a far superior board than the MS2. Less components, it's not as susceptible to interference/noise. It's what most of the commercial MS PNP ECU's are based off.
-- Joe
Old Sep 14, 2015 | 02:36 PM
  #53
kurtis72's Avatar
Engine: l69 & lb9
Transmission: t-5
Tried to do some more tuning, I seem to have inconsistency from one startup to another. I had it idling great around 14.5 AFR. Then I shut it off and re start and it is over 15. So I take some fuel out at idle and it is fine again. I shut it off and wait and now it is really fat (13 or less)
I think it might also make a difference if the laptop is connected.
Old Oct 15, 2015 | 06:59 PM
  #54
kurtis72's Avatar
Engine: l69 & lb9
Transmission: t-5
Just a quick update: I have the car running on MS2 with the Extra Code. There is still more tuning to be done and I have no emissions or speedometer, but I am making progress.
The most important thing I learned:
SKIP THE B&G FIRMWARE. Go right to the Extra 3.4 firmware. It is way more complicated, but it actually works...
Old Oct 16, 2015 | 06:27 PM
  #55
kurtis72's Avatar
Engine: l69 & lb9
Transmission: t-5
IAC Wiring 1991 Camaro 5.0 TPI
The link:
http://www.megamanual.com/ms2/IAC.htm
The square connector at the bottom of this image is what I have:
However, I had to wire it backwards from what they show. I had to swap the two coils to make it work in the correct direction.
The software is set up so IAC=0 is closed, and the motor won't run unless you hold the throttle open. And a high number ~300 is wide open.
This was just for my car, you should check yours and be sure.
Old Feb 27, 2016 | 09:39 PM
  #56
kurtis72's Avatar
Engine: l69 & lb9
Transmission: t-5
I have the speedo/VSS working now. No need for any pull-up resistors. These settings worked for me:
VSS settings for MS3X and 91 Camaro with T-5 Transmission.
Old Feb 28, 2016 | 07:42 AM
  #57
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
How do you like the MS3?
-- Joe
Old Mar 3, 2016 | 07:15 PM
  #58
kurtis72's Avatar
Engine: l69 & lb9
Transmission: t-5
-- Joe
It is great!
I am getting ready to swap a 2010 LS3/TR6060, stay tuned...
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
theurge
Aug 21, 2015 12:46 PM
Thirim
Aug 13, 2015 03:09 PM
Sanjay
Aug 12, 2015 03:41 PM
