multiple trouble codes out of the blue
Car: 1992 Z28
Engine: 5.7
Transmission: Automatic
Hi guys,
I have a 92 Z28 with a 5.7 auto trans and the car suddenly started running very poorly and giving trouble code. The car will start but will start to smell like gas and begin to flood (i think)
The codes are: 15, 21, 43, 53.
I've looked up the codes but I do not know what would cause them to trip all at once. Could it be the alternator or ECM issue? I've already changed the TPS and that didn't change anything. I do not what to start throwing money at what I do not understand.
Thank you,
Rick
Thank you,
Rick
Car: 1992 Z28
Engine: 5.7
Re: multiple trouble codes out of the blue
My question is why would 4 codes appear at once? I doubt that the sensors suddenly all went bad. I changed the TPS and it made no difference, however I think the computer thinks that the throttle is wide open because the engine is flooding with gas.
Car: check
Engine: check
Transmission: check
Time to try another ECM, it will be the 1227730. Most likely will fix it. Be sure to retain your MEMCAL to move over to the other one. See sticky up top for a picture of it.
RBob.
RBob.
RBob.
RBob.
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Multiple codes appearing simultaneously make for easier diagnostics. Find the common item that relates to those codes.
BumpaD82
Feb 26, 2016 02:57 PM
Linson
Sep 21, 2015 01:08 PM
