LS swap looking to tune ecu
Old Aug 17, 2015 | 03:22 PM
nuggie's Avatar
Car: 91 Firebird, 87 E'LS' Camino
Engine: 5.7 TPI, 5.3
Transmission: 700R4,200R4
Axle/Gears: 4.10 Lock Right locker/2.43
I am sorry if this is in the wrong spot but I just bought a LS 5.3 swap (all wiring an ecu out of the donor truck) from a salvage yard for my 87 El Camino. For the time being will install it as stock as possible, but a combo of not really wanting to run 4 O2 sensors (since I don't have a cat set up) and my greed for speed I wanna look into tuning the stock ECU. I have no idea on tuning everyone else I know that has done this has gone with a aftermarket ecu (magesquirt v3) or has gone carbbed. Honestly though I mostly just want to change some simple things such as I am running a non comp controlled trans and emission delete and stuff like that. For later on I do have one that is the MAF setup so it seems like I could be able to throw a mild cam in it no problem. Thanks for all the help guys
Old Aug 24, 2015 | 01:49 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: LS swap looking to tune ecu
Consider looking into HP Tuners...
http://www.hptuners.com/
Old Aug 24, 2015 | 07:18 PM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
Just about any tuner can put a baseline tune into your ECM and delete anything that you don't need. It usually costs around $150-200. That is probably the easiest route to go. If you don't know anyone locally you can mail the ECM to a tuner. Frost is probably the most well known mail order tuner.
Or look into getting HP Tuners and do it yourself as Street Lethal said. HP tuners can pay for itself quickly if you plan on doing more modifications later...cam swaps, gear changes, etc.
Old Aug 25, 2015 | 01:27 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
If most of your friends have gone Megasquirt, you should probably do the same. You'll get support from their experience, and you won't be as limited in the things you wish to change or do. Your goals may change over time.
-- Joe
eightsixseven
Dec 16, 2024 01:50 PM
Caspar
Jun 19, 2016 11:19 PM
E Rod
Aug 28, 2015 05:17 AM
InfinityShade
Aug 22, 2015 08:00 PM
theurge
Aug 21, 2015 12:46 PM
