Ebl p4 flash tuning kit
Old Aug 23, 2015 | 03:54 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Ok so im switching over from maf to sd and also got the ebl flash p4 tuning kit im having a problem i dont have power going to the map sensor i do how ever have power coming out of pin c on the tps sensor which goes from the tps to map sensor what did i do wrong im wondering if i messed up repinning the connectors and put one in the wrong spot
Old Aug 24, 2015 | 08:15 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Ebl p4 flash tuning kit
It's possible that something was re-pinned incorrectly. Also, as the MAP sensor needs to be added in (wired & plumbed), it is possible that the connector for it was wired incorrectly.
Just take your time and double check these items. If you didn't get the re-pin guide let me know and I'll send it.
Also, be sure to use the WUD Diagnostic display to review the sensor values. They will be the raw, direct from the sensor, values.
RBob.
Bubbajones_ya
Jul 6, 2024 08:32 PM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
antman89iroc
36
Jan 31, 2016 08:42 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
Quzyle
Oct 15, 2015 03:35 PM
