Confused on broadcasting code for memcal.
Old Sep 17, 2015 | 02:16 AM
lethaldomestics's Avatar
I just swapped out my 305 tpi to 350. I got everything I need to do the swap except the proper memcal. I want to get from autozone but they say I need the proper broadcast code on the memcal / prom.
My setup is as follows
1987 bird 350 tpi 700r4 tranny. Bosch 3 fuel injectors and all part number correct sensors and relays.
Is there a list for broadcast numbers?
Old Sep 17, 2015 | 08:00 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Confused on broadcasting code for memcal.
There is a list of them, but can't recall where I found it. For your Firebird is will be one of these two:
ABWW w/2.77 rear
ABWT w/3.27 rear
I have no idea if they were superseded, those two were released in '86.
RBob.
Old Sep 17, 2015 | 10:38 AM
ABWW w/2.77 rear
ABWT w/3.27 rear
RBob.
So this for work for the 165 ECM? I thought 86 s came with different ECM s. I'm trying to wrap my head around this whole thing is kind of confusing.
Old Sep 17, 2015 | 12:20 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
They were released in '86 for the '87 MY. Note that in '86 they also used the '7165 ECM, it was in '85 that a different ECM was used.
RBob.
Old Sep 17, 2015 | 03:50 PM
RBob.
Thanks RBob. I apreciate the help.
Old Sep 21, 2015 | 01:18 PM
Were those broadcast codes you gave me California smog does that even matter?
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
