Computer plug locations (pic)
Old Oct 10, 2015 | 06:39 PM
2QUIK4U's Avatar
Car: 1991 Z28
Engine: 5.7 TPI L98
Transmission: 700-R4
Axle/Gears: Moser 9" with 4.11
This makes me look like a moron. I searched before I posted this. I may have even bought a new computer because I plugged the other one in wrong. There are 2 connectors with the same plug type. Which goes where?
Old Oct 11, 2015 | 11:58 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Computer plug locations (pic)
All three plugs are different. Note the center black connector on the ECM, it has 24 pins versus the 32 pins of the other (outer) black connector.
The lime green connector plugs into the ECMs yellow connector.
RBob.
Old Oct 11, 2015 | 05:21 PM
2QUIK4U's Avatar
Car: 1991 Z28
Engine: 5.7 TPI L98
RBob.
Yep! That was my whole issue with no injector pulse on my other threads. I had the 2 outside plugs wrong. They both fit in the wrong spot. She fired right up! Thank you
Old Oct 12, 2015 | 08:23 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
That will do it. Although, the connectors have to have been modified as they are keyed differently between them. Can see the two ribs on the lime green connector in the photo. Then again I've seen ECMs where the connector housings are broken. This would allow the wrong connectors to be used.
RBob.
eddie jr
Nov 6, 2015 05:17 PM
yellowferrari
Oct 12, 2015 11:07 AM
2QUIK4U
Oct 10, 2015 12:29 AM
Pbarnett98
Oct 9, 2015 11:48 AM
Mr. McGuire
Oct 6, 2015 07:54 AM
