Code 42 Gremlin!
Old Nov 14, 2015 | 09:26 PM
DemonYusuke's Avatar
Car: 1991 z28 L98 Spec
Engine: 5.7 350 TPI 245\345
Transmission: 700 R4
Code 42 Gremlin!
I have replaced the distributor and the coil. Code 42 never went away. The strange thing is if i started it cold let it warm up the code wouldnt come on for a few minutes. The motor runs like crap when its cold started but after its warm if i restart it the code will still set but it runs like it should. I'm so confused about this thing. My next step is to replace the ecm. I'm just wondering what you guys think?
Old Nov 15, 2015 | 10:32 AM
bigal55's Avatar
Car: 88 convertible
Engine: 5.7L
Transmission: 4+3 maual
Axle/Gears: 3.07
Re: Code 42 Gremlin!
Have you done the troubleshooting steps for code 42 using an ohm meter and a test light? http://chevythunder.com/est_code_42.htm Follow this chart, it will help determine your problem. HTH!
Old Nov 15, 2015 | 10:41 AM
bigal55's Avatar
Car: 88 convertible
Engine: 5.7L
Axle/Gears: 3.07
Wiring on these cars is over 25 years old so don't overlook the points about open or shorted wiring in the circuit!
Old Nov 15, 2015 | 12:13 PM
I have checked all the wiring I can and it all looks good. No broken casings or ends. I'm gonna pull the ecm and check somw of thw harnesses ground on ckt 423 i believe is the correct one.
soarestransam
Jan 7, 2016 08:02 PM
85@IRocZ
19
Dec 25, 2015 09:33 AM
NiG
Nov 16, 2015 04:52 AM
Necron
Nov 14, 2015 07:07 AM
Skwisgaar
Mid-West Region
Nov 11, 2015 06:17 PM
