door window motor gone?
Car: 1989 Gray ttop GTA
Engine: 5700cc
Transmission: auto 700R4
Hi guys,
I need help
the window motor fails: https://*******/shHv
after and below a certain point, it grinds and has no force at all.
Is the motor damaged?
Do I have to buy something like this: http://www.ebay.com/itm/12-Tooth-Doo...BVzbsR&vxp=mtr
or can it be repaired?
THANKS
I need help
THANKS
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: door window motor gone?
Have you removed that shield on the door & looked at the regulator while the window is moving up/down? Sounds like something could be jammed in the regulator or maybe the teeth on the gear drive.
Engine: 5700cc
well, I dont know what the regulator is
Surely, as I said, the motor has ZERO force below a height levet, and beyond, like if some teeth are broken.
Question is: is it repairable or should I put a brand new motor?
THANKS
Surely, as I said, the motor has ZERO force below a height levet, and beyond, like if some teeth are broken. Question is: is it repairable or should I put a brand new motor?
THANKS
[QUOTE=NiG;5980129]well, I dont know what the regulator is
THANKS[/QUOTE
You will be needing a NEW window motor. Also, expect a few headaches trying to remove the three factory rivets holding the motor.
THANKS[/QUOTE
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Sometimes the metal around the rivets crack.
These links may help.
https://www.thirdgen.org/powerwindows/
https://www.thirdgen.org/forums/body...tall-easy.html
Engine: 5700cc
Thanks guys!! Very usefull
Yeah, yesterday I was quickly watching at some thirdgen window motor replacement tutorials, and I saw that the rivets could be a pain in the ***
Is it so hard?
I'll be watching all the videos and tutorials.
thanks a lot!
:'(Is it so hard?
thanks a lot!
kitt23
Nov 28, 2015 06:24 PM
25thannivZ28
Nov 14, 2015 10:29 PM
camaroinmotion
Nov 8, 2015 11:46 AM
