Non V.A.T.S steering column in V.A.T.S car
Old May 13, 2016 | 11:40 AM
fastfbody's Avatar
Car: 1989 GTA trans am
Engine: L98 350 tpi
Transmission: 700r4 built
Axle/Gears: 3.45 4th gen 10 bolt
Hey guys I got a 1989 GTA trans am. It was being parted out and i got to it after the steering column had been pulled . I have installed a 1985 Trans am column in the GTA . Im going to be trying to start in tomorrow after installing a new distributor . does anyone know of any issue that will come up ? Thanks for any help .
Old May 13, 2016 | 11:46 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: Non V.A.T.S steering column in V.A.T.S car
The column isn't the issue that I'm aware of. It's the key cylinder. You need the key cylinder that supports VATS. If VATS in your 89 has been disabled, then no problem. If not, you need to match the key to the cylinder for the right ohms.
Old May 13, 2016 | 12:55 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
just replace the key cylinder with a non-vats one and do the starter enable relay bypass and you'll be good to go.
Old May 13, 2016 | 01:55 PM
fastfbody's Avatar
Engine: L98 350 tpi
Thanks guys wasn't sure about this 1 .
Old May 13, 2016 | 04:35 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
Just be careful when you take the steering wheel off to swap the lock cylinder and be sure to take plenty of pics on exactly how everything goes.
89irocz355
Mar 28, 2018 08:24 PM
89irocz355
Exterior Parts for Sale
18
Apr 11, 2016 10:17 PM
camcore
Mar 30, 2016 02:46 PM
Nick Fletcher
Mar 22, 2016 01:19 PM
EPenson1
Mar 18, 2016 06:00 AM
