Will a 305 tpi support 350 fuel requirements
Old Dec 29, 2001 | 06:16 PM
BONES LB9's Avatar
i'm planning on replacing my 86 305tpi with a 350. I'm going to get 24# injectors and afpr and i was wondering would the stock ecm provide enough fuel for 350?
Old Dec 30, 2001 | 07:56 AM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
yes it will. with 24# inj. you may run rich. 22# for stock and some lightly moddified 350 eng. are just fine. I have a modded 350 in mine I ran the 24# inj. for a couple years with no problem till I got a job real close then the car being in open loop for most of the drive made me notice real quick It was running rich. ( this is when I got in to chip burning) you only need bigger inj if you run real high rpms or high hp.
Old Dec 30, 2001 | 07:59 AM
Engine: ls1, LB9
you will have to get a 350 tpi chip 87? I think will work on the 86. the 305 chip will work(run) how well I have no Idea the stock 350 chip will be programmed for of course a stock 350 and the 22# inj.
BlueIroc-Z
Jun 9, 2019 03:22 AM
1nastygta
Oct 28, 2015 08:51 PM
Brcharrelson
Aug 26, 2015 07:47 PM
st.evel07
Aug 13, 2015 06:15 PM
drathaar907
Aug 6, 2015 04:20 PM
