Hi,
does anyone know if the AZRC prom is the right one for my LH0 3.1 engine with vin "T"?
I could not find the AZRC prom in the following list:
http://3rdgenformula.com/90/promcodes.htm
Thanks.
Thanks.
That's for a Grand Prix, cutlas 3.1 auto
It would work in a 730 ecm but it came from a 727.
Thanks.
Yes, you are right. It works in the 730 ecm which is installed in my Firebird.
But I am wondering if it is a good idea to leave the ecm as it is. The AZRC prom has been never produced for the "f" platform.
There are also a lot of differences in between the LH0 and LG5 engines (Turbo, ignition coil an so on).
Should I buy an appropriate prom for my LH0 engine?
I'm going to move this thread to the DFI & ECM board, better suited there.
The LG5 engine should be DIS, which means on a LH0 the ignition timing will be way off. I've known folks to open the EST/BYPASS to get around this (temporary fix).
If your car is a stick shift look for a BAWX MEMCAL. If it is an auto (700R4) look for an AZTY MEMCAL.
Thanks, RBob.
I found 13 other proms which could be used for my LH0 from 1990 and auto transmission:
ALSZ
ALTD
ARPM
ARPN
ATFM
ATFN
ATXF
ATXH
AUJW
AUJX
AYCF
AYCH
AZTX
I think AZTY is the newest one? This is why you recommend this prom?
ALSZ
ALTD
ARPM
ARPN
ATFM
ATFN
ATXF
ATXH
AUJW
AUJX
AYCF
AYCH
AZTX
Azty was the latest .bin . The gm part is 16171406 looks to be nla but you should have luck locating one in the classifieds.
If you can't find one let me know, I can reprogram a memcal with that .bin
Hey guys
I also found out that my V6 3.1 LH0 Firebird 1990' was running an AZRC.
It's an automatic transmission so I decided to buy the AZTY PROM module. Can I just swap the PROM or do I need change the ECU completely?
Thanks.
Thanks.
Thanks.
I noticed that the scan id 721 is not only for the AZRC prom. It stands also for the AUJW prom which fits to my Firebird. So I have to look at the prom in order to find out if it is really an AZRC prom at first.
I could not imagine that GM uses the same scan id for two prom units which both work with a 3.1 engine.
For my german friend here who bought his first Firebird seven years ago:
Nein, du brauchst nicht das ganze Steuergerät tauschen. Du kannst das alte behalten. Hab dir heute geschrieben, dass die ID 721 auch ein AUJW sein kann. Das wusste ich gestern noch nicht.
