Vss sensors
Old 09-20-2017, 09:01 PM
Want a title? Post!
Eddie9955's Avatar
Vss sensors
for my 86 camaro does the vss sensor have anything to do with shifting of the transmission or running of the engine? If so what wires is it and where is it located?
Old 09-21-2017, 09:50 AM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Vss sensors
It's probably in the instrument cluster. It helps with iac control and tcc lockup.
Error code 24 may show if it's not functional.
Old 09-21-2017, 04:21 PM
ULTM8Z's Avatar
Re: Vss sensors
On 90-92 $8D, VSS contributes to fan on/off, controls TCC lockup, highway mode fuel and spark, fuel pump cutoff speed-governer function.
Not sure if it's the same on an 86.
Third gens never had electronically controlled shifting though.
Old 09-21-2017, 04:25 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Vss sensors
Originally Posted by ULTM8Z
On 90-92 $8D, VSS contributes to fan on/off, controls TCC lockup, ..., fuel pump cutoff speed-governer function.
Injector cutoff on over speed (RPM or MPH).
RBob.
