What difference between 350 & 305 ecm & why does engine alter when ecm is moved ??
Old Jan 3, 2002 | 01:24 AM
Alan Billingham's Avatar
Car: Camaro IROC
Engine: 305ci
Car in question is a 86 iroc with the original 305 tpi removed and a 85 350 tpi installed. Is the ECM`S different??? Current service no is 1227165 amu. When the car started playing up it was at 1500 rpm at idle with the cooling fans running constantly. All sensors at the cooling side checked for grounding and operation etc, all ok. When ECM is still hooked up with car running, if you move the ECM from side to side or lightly shake it, the car either cuts out or runs as if it is a couple of cylinders down.. My friends 86 305 tpi has installed his ECM in mine for a trial and it seems to work fine. His service no is 16198259. So the final 3 questions are; 1. Is my ECM knackered,
2. Are the 350 & 305 different,
3. If they are different, what service no am I looking for.
ps. The car is an auto.
Cheers ALAN.........
Old Jan 3, 2002 | 08:41 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
The 305s and 350s use the same ECM. However, 1985s used a different ECM (and eprom) than 1986-1989. There is a lot more info on the later 165 ECM (86-89) and generally people prefer the the 1989 calibration ($6E) than the earlier years.
There are different eproms between 305s/350s and standards/automatics. But the ECM on Third Gens are the same provided they are the same year. Also, the SD Vettes used a different ECM than SD F-body cars.
Old Jan 3, 2002 | 02:14 PM
Car: Death Mobile
Engine: 666 c.i.
I got your e-mail. The "259" is a replacement ECM for the "165" btw, but it works exactly as the 165.
Jae992
Aug 27, 2015 09:07 AM
AkDrifted
Aug 17, 2015 07:45 PM
st.evel07
Aug 13, 2015 06:15 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
