ALDL / ECM Bad? Need help :(
Car: Firebird SE
Engine: 5.0 305 LG4
Transmission: Manual
Axle/Gears: 5 Gears
Hello from Germany. At first i hope my English will be well enough that you understand my question. Since a few Days i am a proudly Owner of an Firebird from 1985 with the 5.0L 305 V8 Engine with Carburator. Now my question:
The Engine Service Lamp runs instantly. I read on the Internet how to read out the ECM / Codes. When i connected A to B with an Wire, it doesn`t appear anything. The Light doesn``t flash or go off. It still burns, Ignition OFF / on ... the same ... i`ll try anything but nothing happend... I attached a picture of my ATLD Connector and i wonderes that there is lost the E and G connector.
Could anybody help me? The Engine runs fine and i didn?t have problems yet ... but i will delete the Engine Service Lamp and i think it will be better to know why it burns.
Regardly and best Greetings from good old Germany - Sascha
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: ALDL / ECM Bad? Need help :(
G should be for the lamp driver module. Not sure why it’s missing.
https://www.thirdgen.org/forums/elec...ine-light.html
Engine: Lb9
Transmission: M20
Lamp driver testing
OK, dug up some info on how the CEL is wired. Hopefully this is correct (appears to be).
Do a key-on, engine-off. Ground terminal D in the ALDL connector. The CEL should turn on. If so then the bulb is OK along with the +12 volts to it. This test just grounds the low side of the CEL bulb.
Check the gauges fuse, it powers the lamp driver.
Unplug the ECM then key-on, engine-off, the CEL should light up. If it does then either the ECM is bad, or it is not getting power.
If it doesn't light up then the lamp driver module is bad.
Note that there could also be an open wire somewhere, and not a bad bulb, driver module or such.
There are two power feeds to the ECM: battery +, (orange wire) and IGN+ (pink/black). The battery feed is via a fusable link, the IGN+ feed is via a 15 A fuse (labeled ECS ?).
RBob.
RBob.
Car: Firebird SE
Engine: 5.0 305 LG4
Axle/Gears: 5 Gears
Thank you so much! I will try the test and i think i will order such an Lamp Driver to test. THX from germany and i will reply if the Problem is fixed!
Transmission: 5-speed/T-5
So when you turn the key on, the CEL just turns on and stays on, no flash?
If that's the case the ECM is in LHM (Limp Home Mode), you won't retrieve any codes, except possibly 51 (PROM Error).
You need to figure out why it's in LHM (If it is). This could be a missing power connection, though not usually, a PROM/MEMCAL that is not seated or missing (most common) or a failed PROM/MEMCAL (semi-common). I believe there's a couple other causes but can't recall what they are off hand. Googling a flow chart to diagnose LHM for your year and model should get you some ideas and a way to diagnose the issue.
Car: Firebird SE
Engine: 5.0 305 LG4
Axle/Gears: 5 Gears
Hi, i think it will be not easy to find out. I checked my VIN and was wondered. My VIN says ist is an H with Automatic Transmission but still there is an 5 Gear Manual Transmission in my car
.... i think so the Pre-Owners had do some tricky changes. Actually the Car is not here because i had an little accident. Few days ago i ordered the Lamp Module and hope when i changed it everything will be fine, we will see. Next Step would be a new or remanufactured ECM. If the Problem then not will be fixed i had to follow the Wiring Diagramm to check where the Problem is.
I think a lot of Parts are changed from the Pre Owners. My Speedometer BTW shows maximum 80Mph and runs forward a lot, i think there originally must be an 120MPH or not? I think the next days i would have many questions for here ....
I love this car ... and my passion woulld be to bring him to A++ .... Last days i orderd Parts for over hundreds of Euro
.... But im proud to bring this American way of Live on german Roads back again
.... i think so the Pre-Owners had do some tricky changes. Actually the Car is not here because i had an little accident. Few days ago i ordered the Lamp Module and hope when i changed it everything will be fine, we will see. Next Step would be a new or remanufactured ECM. If the Problem then not will be fixed i had to follow the Wiring Diagramm to check where the Problem is.I think a lot of Parts are changed from the Pre Owners. My Speedometer BTW shows maximum 80Mph and runs forward a lot, i think there originally must be an 120MPH or not? I think the next days i would have many questions for here ....
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Congratulations and Welcome!
As a proud owner, you may want to invest in a scan tool for OBD-I. A scan tool doesn't just read codes it can feed you live information such as mix ratio, timing, sensor readings, etc. and create data log files.
Car: Firebird SE
Engine: 5.0 305 LG4
Axle/Gears: 5 Gears
Hello Tootie, did u have a recommendation for an OBD-I Tool who works with my model? Thx a lot ....
Engine: 350 TPI L98
Transmission: WC T5
You can go one of three routes -
1. Vintage stand alone tools like the OTC 4000
2. Buy laptop software and a cable
3. Buy a bluetooth data transmitter and use your android phone (Apple Devices are not supported), tablet, or bluetooth laptop. You can get these form 1320electronics.com and redevilriver.com. You will still need an app. Basics apps are usually free, cool custom gauge/display apps cost up to $20. see DroidALDL.
Engine: Lb9
Transmission: M20
http://www.winaldl.joby.se
To get the right computer/chip you can look at your ecm. It will have a service number on it. Then look at eBay for a ecm/chip. Your chip has 3 letters on it. This is the identification.
Car: 85 Iron Duke, 88 GTA and 92 TA
Warum besuchst du nicht mal das wohl größte deutschsprachige Forum? www.f-body-nation.com
Da bin ich auch und das Wissen dort ist auch verdammt groß. Sind nicht ganz so viele Experten unterwegs, insbesondere im DIY PROM Bereich, aber deine genannten Probleme sollten dort auch sehr gut behandelt werden können.
Ein perfektes ALDL Diagnoseinterface gibts zum Beispiel von www.1320electronics.com
If anyone here is complaining what I wrote, I just gave him a link to the biggest german 3rd Gen Forum. Maybe we can help him there also in his native language. I am also an active member there and here.
Car: Firebird SE
Engine: 5.0 305 LG4
Axle/Gears: 5 Gears
Hi J.C. ... DANKE werde mich gleich anmelden! Hatte euch nicht gefunden über google! LG
