1991 firebird formula ecm does not supply a grd to fuel injectors
Old Jan 24, 2018 | 09:41 AM
Doug Barr's Avatar
1991 firebird formula 5.0L, VIN F, multi port fuel injection, vehicle will not start since the injectors never receive a ground from the ECM. NO CODES! Replaced ECM, did not help. Checked continuity from 12volt supply through fuel injector wires to input connectors on ECM, everything OK. Original problem was, vehicle would start and run 20 minutes then shut off, no grd for injectors tto fire. Never had a code. Pulled TPS sensor connector got a code for it from the ECM. Can the MEM/CAL cause this problem? I had no Code 51
Old Jan 24, 2018 | 10:41 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 1991 firebird formula ecm does not supply a grd to fuel injectors
Are you sure it’s a ground issue not a icm problem?
Old Jan 24, 2018 | 12:21 PM
Doug Barr's Avatar
The ecm provides the ground for the injectors, they have 12 volts applied to them all the time and the ecm determines which injector to ground based on what the distributor module tells it. To test, I applied a test light to the two leads of one of the injector connectors. When vehicle runs light is on, I checked this out when it was able to run for 20 min. at a time. When it stopped running (like it ran out of gas) I tried to start it and had no light at the injector connector ecm not supplying a ground for the injector
Old Jan 24, 2018 | 12:28 PM
Engine: Lb9
Transmission: M20
Have you used a noid light to check for injector pulse ?
Here is a pinout for your ecm grounds located behind your passengers cylinder head.
http://tpiparts.net/1227730_pinout_diagram
Even with a bad memcal in limp home mode you will have injector pulse.
This is a batch setup the ecm doesn’t fire one at a time.
A shorted injector will shut down the injector driver and kill all eight injectors.
Especially if these are the stock multec injectors.
https://www.southbayfuelinjectors.co...1985-1992.html
Old Jan 24, 2018 | 01:03 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Would def ohm check the injs, esp if they are stock.
Old Jan 25, 2018 | 09:26 AM
ULTM8Z's Avatar
yeah I would check the ignition control module. I believe the ECM uses the signal from that to drive the injectors.
injectors use a switched ground from the ECM with a constant 12V supply. Thus ohming out the ground side of the injector harness with the engine off won't be useful.
Old Feb 1, 2018 | 12:41 PM
Engine: Lb9
Transmission: M20
Did you resolve this issue ?
westicle1
Exterior Parts Wanted
Apr 25, 2008 10:37 AM
327_TPI_77_Maro
Carburetors
Apr 6, 2006 03:33 PM
Rabbitt
May 23, 2004 10:07 PM
