ECM Replaced, won't run now?
Car: 1987 Iroc Z28
Engine: originally 5.0 now 5.7 Block
Replaced the ECM in a 1987 Iroc z..because you couldn't pull codes from the old one and the service light would stay on. It would run with old ecm.
So I installed a new ECM with the prom from the old one.. now you can get the code 12 diagnostic but the car won't run. it will start for a second and die.
Just wondering if any body else has had this problem and if so what was done to resolve it?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: ECM Replaced, won't run now?
Sounds like you might of got a bad ecm. Do the fans come on koeo ?
Engine: Lb9
Transmission: M20
Sounds like a bad ecm out of the box or not the same service number. 1227165, 16198259, 88999194, 77-7165.
Car: 1987 Iroc Z28
Engine: Lb9
Transmission: M20
The fans on with the key on is a sign of a bad ecm or the memcal is not seated.
Are you positive that every pin on the chip made into the socket and none folded under?
IDK, but can the chip be installed backwards?
Engine: Lb9
Transmission: M20
91tpiwrangler
Apr 22, 2018 06:57 PM
gators_bucs_fan
Jun 9, 2016 12:14 PM
84z28h.o.
Carburetors
Aug 25, 2007 01:00 AM
