Code 13 and Low Voltage at ECM
Old Jun 4, 2018 | 09:56 PM
JaredP's Avatar
I just bought an 85 Firebird with the 2.5 engine and TBI. The check engine light came on, and showed code 13, so I replaced the oxygen sensor in the hope that it was just a bad sensor. Unfortunately that did not fix the issue. So I checked the voltage at the ECM for the oxygen sensor and its ground, and it is only reason .18 bolts when it is supposed to be around .45 volts when in an open loop. The engine never goes to a closed loop, so that voltage is not changing at all. Do you guys think that my ECM is bad, or that there is just a short in the wire going to the oxygen sensor, or maybe just a bad connector at the oxygen sensor?
Old Jun 13, 2018 | 03:49 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Code 13 and Low Voltage at ECM
You should refer to a gm fsm or google your service number of the ecm to see if you can find a schematic. It should be a purple wire at the ecm. In cl if the o2 mv are toggling at the ecm pin for the o2 the ecm would be faulty.
Buck268
May 23, 2003 01:37 PM
Mike '91 Z28
Jan 3, 2001 08:53 PM
IROC212
Oct 13, 2000 07:47 PM
james_fearn
Jul 25, 2000 06:44 AM
