Code 43. Low voltage at electronic spark timing circuit
Old Jan 3, 2001 | 05:32 PM
Mike '91 Z28's Avatar
That's the only code I appear to be throwing but do not know why I am getting it. Any ideas in where do I look?
Another question is that my car starts but I have to push the gas pedal 1/4-1/2 to keep it from stalling out. And at 1/4-1/2 the rpm is bouncing around 1000rpm. Could this code 43 be the problem of this or do I got a bigger problem? Another thing is that after 10secs the coated headers are really really hot.
Info:
Just completed a head and cam swap on a 305TPI auto.
[This message has been edited by Mike '91 Z28 (edited January 03, 2001).]
Old Jan 3, 2001 | 07:19 PM
Vader's Avatar
Mike,
A '43' can also be a TPS out of adjustment, which would account for the need to hold open the throttle to keep idle speed. The TPS adjustment error can also indicate a TPS failure, or TPS circuit failure, like the connector improperly connected.
Stat with the TPS and minimum idle speed adjustment. Once it's running, look into a different PROM for the ECM, since the SD cars don't like cam changes very well without program changes.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Old Jan 3, 2001 | 08:53 PM
Vader,
That sounds like a reasonable answer, thanks. BTW would an out of adjusment TPS cause my idle to be kind of jumpy? When I get past 2500rpm, it revs smoothly but lean (can tell because headers are VERY HOT after 5-10 seconds.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
89GTAOz
May 16, 2020 09:31 AM
