Key off eng still runs?
Old Jun 27, 2018 | 11:37 PM
thrdgncamaro's Avatar
Car: 1983 Camaro Base
Engine: 4.8 LS POWA and CHINA boi turbo
Transmission: TH350 w/ Shift kit 3200 stall
So I did a turbo LS swap in my camaro and everything is working great but when I turn the key off the boost gauge and AFR gauge lights flicker and the engine will diesel for a little while. Ive checked my grounds and they seem good. What would cause that to happen? Back feed through something? Any ideas let me know. Thanks
Old Jun 28, 2018 | 06:28 AM
PaulyC's Avatar
Re: Key off eng still runs?
Usually, all else being in good shape, spark plug heat range is usually the culprit when dieseling occurs. Try a colder plug range, make sure your timing isn’t too aggressive and see if it helps.
articwhiteZ
Aftermarket Product Review
Nov 22, 2017 10:04 PM
86speediroc
Feb 20, 2011 08:50 PM
camarogundam
May 30, 2009 08:06 AM
